FS Winfield H Side Draft Carburetor
Posted: Tue Dec 19, 2023 10:55 am
Original Ed Winfield H side draft racing carburetor. The rarest of them all. Good rebuildable condition, complete with barrel float. Throttle barrel nice, turns smooth in bore. Brass throttle arm will need worn oval hole on end brazed and re-drilled back to shape for desired throttle linkage. Cast aluminum body, no pot metal. 2-11/16 between mounting holes, 1-3/8 opening. Included two float needle seats, one modified, one unmodified so the needle can be sealed and reset. 600 includes shipping.
