55 YEAR COLLECTION MODEL T FORD PARTS
Topic author - Posts: 329
- First Name: Herbert
- Last Name: Chaffin
- * REQUIRED* Type and Year of Model Ts owned: 1909 touring, 1911 touring, 1913 roadster, 1914 touring
- MTFCA Number: 227
MODEL T PARTS COLLECTION
YOU WON'T FIND A BETTER DEAL ANYWHERE
PRICES SHOWN ARE FAIR MARKET VALUE
ASKING 15.5 CENTS ON THE DOLLAR (X.155) THATS DIRT CHEAP
BUYER MUST BUY ENTIRE COLLECTION TO GET THESE PRICES
NO INDIVIDUAL PARTS SALES
NOTE: PROGRAM WILL NOT LET ME DOWNLOAD ALL OF THE PICTURES. IF YOU WANT ALL OF THE PICTURES PLEASE CONTACT US AND WE WILL SEND THEM TO YOU.
FAIR MARKET VALUE EXAMPLE,
WHAT YOU PAY
MOTORS AND BLOCKS
1915 BLOCK 500.00 77.50
1916 ENGINE 1,000.00 155.00
WITH LOW HEAD AND EARLY PAN
1916 ENGINE 800.00 124.00
1916 BLOCK 300.00 46.50
1919 BLOCK 100.00 16.80
1919 BLOCK 100.00 15.50
1920 SHORT BLOCK 150.00 23.25
1920 BLOCK 100.00 15.50
1921 BLOCK 100.00 15.50
1922 BLOCK 100.00 15.50
1923 BLOCK 100.00 15.50
1924 BLOCK 100.00 15.50
1925 BLOCK WITH CRANK 150.00 23.25
1925 BLOCK 100.00 15.50
1926-27 ENGINE 800.00 124.00
1926-27 BLOCK 500.00 77.50
TOTAL $7,800.00 $1,210.30
MOTOR PARTS FAIR MARKET VALUE TOTAL
8 FMC VALVES 3.00 24.00
4 ALUMINUM PISTONS AND 300.00 300.00
RODS, GOOD BABBITT
4 ALUMINUM PISTONS AND RODS, USED 100.00 100.00
47 CAST IRON PISTONS 5.00 235.00
30 LIGHT RODS 20.00 600.00
66 HEAVY RODS 5.00 330.00
161 ROD CAPS 5.00 805.00
472 ROD BOLTS 2.00 944.00
150 ROD CLAMP BOLTS 1.00 150.00
# 2 LOW HEADS 125.00 250.00
23 HEADS 50.00 1,150.00
40 LOW HEAD BOLTS 2.00 80.00
195 HIGH HEAD BOLTS 2.00 390.00
32 DOMED HEADBOLTS 2.00 64.00
201 SPARK PLUGS 1.00 201.00
37 CRANKS 50.00 1,850.00
56 FRONT MAIN BEARING CAP 10.00 560.00
17 CENTER MAIN BEARING CAP 10.00 170.00
43 REAR MAIN BEARING CAP 10.00 430.00
206 FRONT AND CENTER 2.00 412.00
MAIN BEARING BOLTS
82 REAR MAIN BEARING BOLT 2.00 164.00
33 CRANK GEARS 10.00 330.00
2 TIMING COVERS (16-19) 50.00 100.00
17 TIMING COVERS (20-25) 25.00 425.00
7 PAIR EARLY VALVE COVERS 40.00 280.00
26 LATE VALVE COVERS 20.00 520.00
11 EARLY CRANK PULLEYS 25.00 275.00
54 LATE CRANK PULLEYS 15.00 810.00
6 FLANGED CRANK PULLEYS 20.00 120.00
16 CRANK PULLEY PINS 1.00 120.00
# 2 13-15 PANS 250.00 500.00
5 1916-25 PANS 50.00 250.00
# 9 1926-27 PANS 150.00 1,350.00
14 3 DIP LOWER PAN COVERS 35.00 470.00
AND HORSE SHOES
13 4 DIP LOWER PAN COVERS 50.00 650.00
AND HORSE SHOES
10 SETS PAN HORSE SHOES 20.00 200.00
8 PAIR 26-27 OIL PAN 45.00 337.50
CORNER BRACKETS
10 EARLY CRANK PULLEYS 20.00 200.00
53 LATE CRANK PULLEYS 15.00 795.00
6 ACCESSORY FLANGED 30.00 180.00
CRANK PULLEYS
3 OIL CAPS 20.00 60.00
35 EARLY INTERNAL OIL LINES 10.00 350.00
5 LATE INTERNAL OIL LINES 10.00 50.00
# 6 EARLY BRASS HUB FANS 75,00 450.00
2 1916-21 CRANK HANDLES 25.00 50.00
10 1921-27 CRANK HANDLES 25.00 250.00
28 CRANK RATCHETS 10.00 280.00
300 OILERS 0.50 150.00
40 OIL COCKS 1.00 40.00
10 OIL PAN RADIUS ROD CAPS 3.00 30.00
10 ACCESSORY RADIUS ROD CAPS 3.00 30.00
17 CAMSHAFTS 10.00 170.00
37 CAMSHAFTS 20.00 740.00
190 CAM GEAR NUTS 3.00 570.00
55 CAM GEARS 10.00 550.00
43 CAM NUTS 1.00 34.00
20 CAM GEAR PIN 1.00 20.00
22 1909-25 CAM BEARINGS 5.00 110.00
12 1926-27 CAM BEARINGS 5.00 60.00
13 CENTER CAM BEARINGS 5.00 65.00
42 CAM BEARING SPRINGS 2.00 84.00
12 FOURTH MAIN BEARINGS 20.00 240.00
13 SIDE WATER FITTINGS 10.00 130.00
6 EARLY FRONT WATER FITTINGS 10.00 60.00
17 FRONT WATER FITTINGS 10.00 170.00
18 WATER PUMPS 50.00 900.00
4 WATER PUMP PULLYS 10.00 40.00
1 WATER PUMP SHAFT 10.00 10.00
TOTAL 23,282.50
TRANSMISSIONS
# 3 EARLY TRANSMISSIONS, 1913-19 330.00 900.00
# 7 LATE TRANSMISSIONS, 1919-25 300.00 2,700.00
# 1 1926-27 TRANSMISSION 300.00 300.00
TOTAL 3900.00
TRANSMISSION PARTS
20 FLYWHEEL 50.00 1,000.00
16 FLYWHEEL WITH MAGNETS 75.00 1,200.00
306 MAGNETS 5.00 1,530.00
79 MAGNITO COILS 25.00 1,975.00
1 MAGNETO COIL SHIM 2.00 2.00
108 MAGNET SUPPORT BOLTS 1.00 108.00
78 FLYWHEEL BOLTS 1.50 117.00
25 FLYWHEEL PINS 1.00 25.00
300 MAGNET KEEPERS 1.00 300.00
2,400 CLUTCH DISC’S 1.00 300.00
300 BRASS SCREWS .50 150.00
100 TRANS. THRUST WASHERS 1.00 100.00
18 CLUTCH FINGERS 2.00 36.00
60 MAIN SHAFT 35.00 2,100.00
# 28 REVERSE DRUM 100.00 3,000.00
# 20 LOW DRUM 100.00 2,000.00
# 21 EARLY BRAKE DRUM 100.00 1,900.00
# 2 LATE BRAKE DRUM 100.00 200.00
18 DRIVE GEAR 20.00 360.00
50 DRIVE GEAR KEYS 1.00 50.00
55 1909-25 DRIVE PLATES 50.00 3,000.00
22 1926-27 DRIVE PLATES 50.00 1,100.00
171 DRIVE PLATE BOLTS 1.00 171.00
# 94 TRIPLE GEARS 40.00 3,760.00
73 CLUTCH DRUMS 30.00 2,190.00
54 CLUTCH THROWOUT COLLARS 20.00 1,080.00
58 CLUTCH SPRINGS 5.00 290.00
58 CLUTCH SPRING CUPS 5.00 290.00
7 BRASS CLUTCH PUSH RING 10.00 70.00
27 PEDAL CAMS 1.00 27.00
13 LOW PEDAL CAMS 1.00 13.00
15 1916-25 BRAKE PEDALS 10..00 150.00
11 1926-27 BRAKE PEDALS 10.00 10.00
29 REVERSE PEDALS 10.00 290.00
3 LOW SPEED PEDALS 10.00 30.00
18 LOW SPEED ADJUSTMENT SCREW 5.00 85.00
30 PEDAL NUTS 1.00 30.00
38 DEMOUNT ABLE BANDS 25.00 950.00
93 NON DEMOUNTABLE BANDS 5.00 465.00
15 LOW SPEED ADJUSTMENT SHAFTS 2.00 30.00
12 LOW SPEED CLEVIS LINKAGE 5.00 60.00
28 PEDEL SPRINGS .50 14.00
10 PEDAL SHAFTS 1.00 10.00
TOTAL 30,568.00
TRANSMISSION COVERS
2 ALUMINUM TRANSMISSION COVERS 125.00 250.00
8 16-19 TRANSMISSION COVERS 50.00 400.00
7 20-25 TRANSMISSION COVERS 50.00 350.00
5 TRANSMISSION COVER PLATES, FLAT 15.00 75.00
41 TRANSMISSION COVER 10.00 410.00
PLATES (16-27)
7 MAGNITO POST 1909-15 8.00 56.00
28 MAGNITO POSWT 8.00 224.00
11 MAGNITO POST 1926-27 8.00 88.00
20 MAGNITO POST OILER 1912-25 10.00 200.00
11 MAGNITO POST OILERS 1926-27 10.00 110.00
2 FORD FAITHFUL TYPE OILERS 20.00 40.00
3 TRANS COVER OILERS 10.00 30.00
4 OIL SCREENS 10.00 40.00
TOTAL 2,273.00
STARTERS
# 62 STARTERS 50.00 3,100.00
STARTER PARTS
13 FIELD ASSEMBLIES 10.00 130.00
4 FRONT SUPPORT HOUSINGS 5.00 20.00
9 REAR BRUSH COVERS 5.00 45.00
10 BRUSH HOLDERS 5.00 50.00
16 STARTER SPRINGS 3.00 48.00
15 REAR COVERS 3.00 45.00
TOTAL 338.00
BENDIX
# 56 BENDIX 50.00 2,800.00
16 BENDIX SPRINGS 1.00 16.00
17 BENDIX DRIVE HEADS 5.00 85.00
14 BENDIX SLEVE ENDS 3.00 42.00
15 BENDIX COVERS 10.00 150.00
TOTAL 3,093.00
STARTER SWITCH
6 STARTER SWITCH AND EXTENSIONS 2.00 12.00
TOTAL 12.00
GENERATORS
# 98 GENERATOR 50.00 4,900.00
TOTAL 4,900.00
GENERATOR PARTS
25 FIELD ASSEMBLIES 10.00 250.00
2 ARMATURES 10.00 20.00
17 BRUSH HOLDERS AND PARTS 5.00 85.00
78 SEAL WASHERS .50 39.00
18 BRUSH HOLDER LOCK RINGS 2.00 36.00
5 FRONT COVERS 5.00 25.00
72 GEARS 4.00 288.00
20 bearings 1.00 20.00
15 REAR COVERS 2.00 30.00
TOTAL 793.00
FANS
# 6 EARLY BRASS HUB FANS 75.00 450.00
10 1916-20 FANS 35.00 350.00
9 1921-24 FANS 35.00 315.00
1 1926-27 FAN 35.00 35.00
10 1916-25 FAN HUBS 8.00 80.00
10 1926-27 FAN HUBS 15.00 150.00
18 FAN BLADES 5.00 90.00
10 1916-25 FAN BLADES 8.00 80.00
26 FAN ARMS 5.00 130.00
1 FAN ARM , PULLY AND SHAFT 10.00 10.00
76 FAN SHAFTS 5.00 380.00
14 FAN MOUNTING BOLTS 2.00 28.00
TOTAL 2,098.00
MANIFOLDS AND EXHAUST
84 INTAKE MANIFOLDS 5.00 420.00
16 EXHAUST MANIFOLDS 10.00 160.00
14 EXHAUST PACK NUTS 5.00 70.00
21 EARLY MANIFOLD CLAMPS 8.00 168 00
5 EXHAUST PIPES 10.00 50.00
28 HOT AIR PIPES 5.00 140.00
2 CUTOUT PEDALS 5.00 10.00
8 26-27 MANIFOLD CLAMP BOLTS 3.00 24.00
2 MANIFOLD CLAMP BOLTS 1.00 2.00
TOTAL 1,044.00
MUFFLERS
1 CAST END MUFFLER 25.00 25.00
1 STEEL END MUFFLER 20.00 20.00
1 CAST END WITH TAIL PIPE 25.00 25.00
1 PAIR CAST IRON MUFFLER ENDS 15.00 15.00
1 PAIR STEEL EMUFFLER ENDS 10.00 10.00
18 MUFFLER SHELLS 2.00 36.00
TOTAL 131.00
CARBURETORS
14 HOLLY G CARBURETORS 40.00 560.00
8 L2 KINGSTON CARBURETORS 35.00 280.00
15 L4 KINGSTON CARBURETORS 35.00 525.00
41 HOLLY NH CARBURETORS 50.00 2,050.00
5 VAPORIZER CARBURETORS 40.00 200.00
1 VAPORIZER INTAKE 5.00 5.00
35 CARBURETOR BOWLS 5.00 175.00
37 CARBURETOR FLOATS 3.00 111.00
11 NEEDLES 5.00 55.00
7 CHOKES 5.00 35.00
25 BOTTOM NUTS 3.00 75.00
3 DASH CHOKE SWIVELS 5.00 15.00
6 CARBURETOR CONTROL RODS 6.00 36.00
52 CARBURETOR AND SPARK 5.00 260.00
CONTROL RODS
TOTAL 4,382.00
FRAME
2 FRAMES 125.00 250.00
FRAME PARTS
5 FRONT CROSSMEMBERS 25.00 250.00
3 REAR CROSSMEMBERS 25.00 150.00
2 1909-21 FRONT MOTOR MOUNTS 35.00 70.00
8 1922-24 FRONT MOTOR MOUNTS 35.00 280.00
15 1925-27 FRONT MOTOR MOUNTS 35.00 525.00
1.5 PAIR 1911-15 FIREWALL 75.00 112.50
MOUNTING BRACKETS
6 PAIR 1916-19 FIREWALL 25.00 150.00
MOUNTING BRACKETS
13 PAIR 1920-25 FIREWALL 25.00 325.00
MOUNTING BRACKETS
2 BATTERY CABLE SUPPPORTS 5.00 10.00
1 BATTERY BOX 25.00 25.00
1 HAND BRAKE CROSS SHAFT 10.00 10.00
TOTAL 1,907.50
GAS TANK
11 SETS 1913-22 GAS TANK MTG. BKTS. 25.00 275.00
10.5 SETS 1923-27 GAS TANK MTG. BKTS 25.00 262.50
9 GAS CAPS 5.00 `` 45.00
42 BRASS SEDIMENT BULBS 10.00 420.00
CAST IRON SEDIMENT BULBS
3 26-27 SEDIMENT BULBS 10.00 30.00
1 GAS LINE FILTER 5.00 5.00
TOTAL 1,037.50
FRONT AXLE
1 1911-19 FRONT AXLE WITH PERCHES 150.00 150.00
5 1920-27 FRONT AXLE WITH PERCHES 200.00 1,000.00
SPRINGS AND SPINDLES
3 1920-27 FRONT AXLES WITH PERCHES 140.00 420.00
AND SPINDLES
1 1920-27 FRONT AXLE WITH SPINDLES 120.00 120.00
5 FRONT AXLES WITH PERCHES 120.00 500.00
16 1920-27 FRONT AXLES WITH NO 50.00 800.00
SPINDLES OR PERCHES
1 1909-12 FRONT SPRING PERCH 20.00 20.00
8 1913-15 SPRING PERCH 20.00 160.00
29 1916-21 SPRING PERCH 10.00 290.00
68 1922-27 SPRING PERCH 10.00 680.00
5 DRAG LINKS 35.00 175.00
38 TIE RODS 25.00 950.00
1 EARLY WISH BONE 25.00 25.00
18 WISHBONES 25.00 450.00
26 SPINDLE ARMS 10.00 260.00
59 FRONT SPINDLES 20.00 1,180.00
27 SPINDLE BOLTS 2.00 54.00
110 TIE ROD BOLTS .50 110.50
21 TIE ROD CAPS 5.00 105.00
7 RADIUS ROD CAPS 5.00 35.00
10 TIE ROD BALLS 5.00 50.00
2 RADIUS ROD ENDS 8.00 16.00
45 FRONT INNER BEARINGS 5.00 225.00
31 FR0ONT OUTER BEARINGS 5.00 155.00
25 FRONT HUB NUT 2.00 50.00
TOTAL 7,980.50
SPRINGS
12 FRONT SPRINGS 100.00 1,200.00
79 FRONT SPRING LEAVES 5.00 395.00
5 TAPER LEAF SPRING LEAVES 10.00 50.00
8 REAR SPRINGS 100.00 800.00
31 REAR SPRING LEAVES 5.00 155.00
1.5 FRONT SPRING CLAMPS 8.00 12.00
1 REAR SPRING CLAMP SETS 8.00 8.00
TOTAL 2,620.00
DRIVE SHAFTS
3 DRIVE SHAFT ASSEMBLIES 100.00 300.00
11 DRIVE SHAFTS 50.00 550.00
2 SHORT DRIVE SHAFT TUBES 25.00 50.00
# 9 EARLY DRIVE SHAFT TUBES 75.00 675.00
2 LATE DRIVE SHAFT TUBES 25.00 50.00
5 DRIVE SHAFT BALL ASSEMBLIES 5.00 25.00
12 DRIVE SHAFT BALL COLLARS 5.00 60.00
19 U-JOINTS, GOOD 50.00 1,250.00
10 U-JOINTS, BAD 5.00 50.00
10 DRIVE SHAFT SLEEVES 5.00 50.00
5 EARLY DRIVE SHAFT SPOOL RACES 5.00 25.00
24 EARLY DRIVE SHAFT THRUST WASHERS 10.00 240.00
20 LATE DRIVE SHAFT THRUST BEARINGS 10.00 200.00
5 DRIVE SHAFT SPOOLS 10.00 50.00
23 DRIVE SHAFT THRUST BEARING ASSY 10.00 230.00
6 DRIVE SHAFT THRUST BEARINGS 8.00 48.00
89 DRIVE SHAFT SPOOL STUDS AND NUTS 1.00 89.00
25 DRIVE SHAFT SPOOL BOLTS 1.00 25.00
33 PAIR RADIUS RODS 75.00 2,475.00
10 MISC RADIUS RODS NEED WORK 5.00 50.00
30 RADIUS ROD SUPPORT BRACKETS 2.00 60.00
186 RADIUS ROD BO0LTS 1.00 186.00
50 DRIVE SHAFT LARGE OILERS 4.00 200.00
TOTAL 6,938.00
REAR AXLE ASSEMBLIES
4 1916-22 REAR AXLE ASSEMBLIES WITH 400.00 1,600.00
DRIVE SHAFT
6 1916-22 REAR AXLE ASSEMBLIS WITH 300.00 1,800.00
OUT DRIVE SHAFTS
2 1926-27 REAR AXLE ASSEMBLIES WITH 400.00 800.00
DRIVE SHAFTS
1 1926-27 REAR AXLE ASSEMBLY WITH 300.00 300.00
OUT DRIVE SHAFT
TOTAL 4,500.00
REAR AXLE PARTS
1 DIFFERENTIAL ASSEMBLY WITH AXLES 250.00 250.00
1 DIFFERENTIAL ASSEMBLY WITH AXLES 325.00 325.00
AND RING GEAR
25 REAR AXLE HOUSINGS 10.00 250.00
35 AXLES WITH GEARS 75.00 2,625.00
30 AXLES, NO GEARS 50.00 1,500.00
26 AXLE GEARS 25.00 650.00
# 31 DIFFERENTIAL ASSEMBLIES, GOOD 100.00 3,100.00
46 DIFFERENTIAL ASSEMBLIES, 20.00 920.00
NEED REPAIR
10 SMALL HALF, DIFFERENTIAL 50.00 500.00
55 DIFFERENTIAL SPIDERS AND GEARS 50.00 2,750.00
34 SPIDERS, NO GEARS 20.00 680.00
38 RING GEARS 75.00 2,850.00
14 11 TOOTH PINIONS 75.00 305.00
40 26-27 BRAKE BACKING PLATES 5.00 200.00
30 PAIR REAR SPRING U-BOLT SETS 35.00 1,050.00
4 PAIR 1909-25 CAST IRON BRAKE SHOES 5.00 20.00
9 PAIR 1909-25 ACCESSORY LINED 10.00 90.00
BRAKE SHOES
6 1926-27 BRAKE DRUMS 25.00 150.00
2 1926-27 BRAKE DRUMS WITH HUBS 50.00 100.00
3.5 PAIR 26-27 BRAKE SHOES 35.00 1222.50
40 1909-25 BRAKE DRUMS 25.00 1,000.00
14 SNUBBER SPRINGS 1.00 14.00
2 MODERN AXLE BEARINGS 20.00 40.00
84 AXLE BEARINGS 5.00 420.00
5 AXLE SLEEVES 1.00 5.00
50 BRAKE PIVOT BOLTS 1.00 50.00
27 LONG DIFFERENTIAL BOLTS 1.00 27.00
80 LONG DIFFERENTIAL STUDS AND NUTS 1.00 80.00
300 OUTER HOUSING BOLTS 1.00 300.00
60 DIFFERENTIAL HOUSING PLUGS 1.00 20.00
300 DIFFERENTIAL STEEL WASHERS 1.00 300.00
73 EARLY REAR AXLE SPRING HANGERS 8.00 584.00
11 LATE REAR AXLE SPRING HANGERS 8.00 88.00
125 EARLY BRAKE CAM ARMS 8.00 1000.00
26 LATE BRAKE CAM ARMS 8.00 208.00
22 PAIR 1916-25 RADIUS RODS 25.00 550.00
3 PAIR 26-27 RADIUS RODS 25.00 75.00
2 SHORT RADIUS ROD SETS 25.00 50.00
6 BRAKE ROD SETS, NEED REPAIR 5.00 30.00
25 1916-25 BRAKE ROD SETS 10.00 250.00
1 SHORT BRAKE ROD SET 10.00 10.00
4 1926-27 BRAKE ROD SETS 10.00 40.00
5 BRAKE ROD CLEVIS 5.00 25.00
2 BRAKE ROD SUPPORT SETS 8.00 16.00
1 OUTER SEAL SET, ALUMINUM 10.00 10.00
10 LARGE OILERS 3.00 30.00
37 MEDIUM OILERS 1.00 37.00
225 SMALL OILERS 1.00 225.00
92 ZIRC FITTINGS 1.00 92.00
96 TWIST OILERS 1.00 96.00
TOTAL 25,239.50
SHACKLES
1 PAIR 1909-12 FRONT SHACKLES 20.00 20.00
1 PAIR 1909-12 REAR SHACKLES 20.00 20.00
8 PAIR 1913-17 FRONT SHACKLES 20.00 160.00
8 PAIR 1913-17 REAR SHACKLES 20.00 160.00
70 PAIR 1917-22 FRONT SHACKLES 10.00 700.00
30 PAIR 1917-22C REAR SHACKLES 10.00 300.00
74 PAIR 1922-27 FRONT SHACKLES 10.00 740.00
41 PAIR 1922-27 REAR SHACKLES 10.00 410.00
31 PAIR 1922-27 SPRING SHACKLES, REPAIR 5.00 155.00
68 BRASS EARLY SHACKLE OILERS 3.00 204.00
TOTAL 2,869.00
WHEELS
4 30X3 ROUND FELLOW WHEELS, NO HUBS 25.00 100.00
2 30X3 SQUARE FELLOW WHEELS WITH HUBS 35.00 70.00
2 30X3 SQUARE FELLOW WHEELS, NO HUBS 25.00 50.00
2 30X3.5 SQUARE FELLOW WHEELS, NO HUBS 25.00 50.00
2 30X3.5 DEMOUNTABLE WHEELS, 25.00 50.00
GOOD WOOD
12 30X3 NON DEMOUNTABLE RIMS 25.00 300.00
8 30X3.5 NON DEMOUNTABLE WHEEL RIM 25.00 200.00
5 30X3.5 DEMOUNTABLE RIM 5.00 25.00
4 30X3.5 DEMOUNTABLE RIMS, GOOD 25.00 100.00
2 21 INCH SPLIT RIMS 25.00 50.00
54 FRONT HUBS 25.00 1,350.00
41 REAR HUBS 25.00 1,025.00
26 HUB BACKING PLATES 5.00 130.00
3 WHEEL PULLERS 25.00 75.00
68 WIRE WHEEL HUB NUTS 1.00 68.00
3 WHIRE WHEEL HUB CAPS, INNER 2.00 6.00
1 WIRE WHEEL HUB CAP 10.00 10.00
6 REAR ALE CAPS 1.00 6.00
24 TRUCK RIM LUGS 2.00 48.00
3 30X3.5 RIM LUGS 5.00 15.00
39 METAL STEM TUBE VALVES AND COVERS 1.00 39.00
30 FRONT WHEEL HUB COVER PLATES 5.00 150.00
3 PLATES FOR WOOD FELLOW WHEELS 5.00 15.00
1 SPARE TIRE CARRIER 50.00 50.00
6 SPARE TIRE CARRIER ARMS 10.00 60.00
5 SPARE TIRE BRACKETS 5,00 25.00
1 21 INCH RIM SPREADER 45.00 45.00
45 FRONT OUTER BEARINGS AND RACES 5.00 225.00
31 INNER FRONT BEARINGS AND RACES 5.00 155.00
TOTAL 4,542.00
BODY, FENDERS AND RUNNING BOARDS
3 LOW FIREWALL 50.00 150.00
2 HIGH FIREWALL 50.00 100.00
5 PAIR DOOR WINDOW ESCUSSION PLATES 10.00 50.00
1 PAIR CLOSED CAR BODY SILL PLATES 10.00 10.00
1 SET WOOD PICKUP BOX IRONS 25.00 25.00
2 PAIR 1923-25 REAR TOURING FENDER IRONS 25.00 50.00
2 PAIR 1914-22 REAR TOURING FENDER IRONS 45.00 90.00
MISC BODY BRACKETS AND IRONS 50.00 50.00
1 1919-22 ROADSTER AND TOURING DASH 35.00 35.00
12 FRONT LICENCE BRACKETS 5.00 60.00
1 1914 DOOR LOCK 50.00 50.00
5 1916-22 DOOR LOCKS 20.00 100.00
10 1923-25 DOOR LOCKS 20.00 200.00
3 MISC DOOR LOCKS 10.00 30.00
6 DOOR LOCK SPRINGS 1.00 6.00
35 STRIKER PLATES 5.00 175.00
1 CLOSED CAR DOOR HANDLE 10.00 10.00
1 STIRRUP HANDLE 10.00 10.00
1 ROBE RAIL 50.00 50.00
13 MISC RODS AND CLEVISES 20.00 20.00
2 SETS EARLY RUNNNG BOARD BRACKETS 50.00 100.00
20 FENDER MOUNTING BRACKETS ON FENDERS 5.00 100.00
3 FOOT THROTTLE CONTROL BRACKETS 10.00 30.00
11 FRONT BODY BRACKETS 10.00 110.00
27 DOOR HINGES 10.00 270.00
3 BODY PATCH PANELS 5.00 15.00
13 HAND BRAKE RATCHETS 3.00 39.00
2 EARLY HAND BRAKE PLATES 5.00 10.00
1 LATE HAND BRAKE PLATE 5.00 5.00
20 BODY BRACKETS 1.00 20.00
30 CLEVIS PINS .50 15.00
2 CLOSED CAR DOORS 100.00 200.00
6 TOURING REAR DOORS 25.00 150.00
3 LOW COWLS 25.00 75.00
2 SEAT PANS 10.00 20.00
3 DASH 10.00 30.00
3 UPHOLSTERY END CAPS 5.00 15.00
TOTAL 2,475.00
HOODS
2 LOW HOOD SIDES 30.00 30.00
1 PAIR HOOD HANDLES 10.00 10.00
8 PAIR 1916-22 HOOD SHELVES 10.00 80.00
2 PAIR 1926-27 HOOD SHELVES 10.00 20.00
1 SET 1911 HOOD HOOKS 25.00 25.00
20 SETS 1916-27 HOOD HOOKS 10.00 200.00
TOTAL 365.00
RADIATORS
1 BRASS RADIATOR 100.00 100.00
1 LOW RADIATOR 50.00 50.00
108 BRASS PETCOCK 2.00 216.00
42 MODEL T BRASS PET COCK 2.00 84.00
70 MISC ODD OIL COCKS 1.00 70.00
1 LOW RADIATOR SHELL 50.00 50.00
1 RADIATOR TOP FITTING 5.00 5.00
1 RADIATOR CAP 10.00 10.00
TOTAL 585.00
BODY AND LIGHT BRACKETS
3.5 SETS 1911-15 PEDAL PLATES 25.00 87.50
9 SETS 1916-22 PEDAL PLATES 10.00 90.00
6 SETS 1926-27 PEDAL PLATES 10.00 60.00
# 1 SET 1913-14 SIDE LIGHT BRACKETS 45.00 45.00
3.5 SETS 1916-22 CLOSED CAR SIDE 30.00 105.00
LIGHT BRACKETS
# 7 PAIR ROADSTER FENDER IRONS 150.00 1,050.00
5 TOURING REAR TAILLIGHT AND 45.00 225.00
LICENCE BRACKETS
3 ROADSTER TAILLIGHT AND LICENCE BRACKETS45.00 135.00
2 TAILLIGHT BRACKETS 25.00 50.00
1 PAIR 1911-14 HEADLIGHT MOUNTING FORKS 75.00 75.00
1 PAIR NON FORD HEADLIGHTFORKS 50.00 50.00
5 PAIR REAR L IRONS 25,00 125.00
1 1926-27 TAILLAMP SUPPORT ARM 15.00 15.00
1 TAILLAMP SUPPORT BRACKET 10.00 10.00
1 TAILLAMP AND LICENCE BRACKET 10.00 10.00
1 FENDER MOUNTING BRACKET 5.00 5.00
2 BATTERY HOULDER BRACKETS 5.00 10.00
TOTAL 2,147.50
STEERING
11 STEERING COLUMNS 200.00 2,200.00
12 STEERING SHAFTS 50.00 600.00
1 WOOD STEERING WHEEL 25.00 25.00
5 1916-25 STEERONG WHEELS WITH SPIDERS 75.00 375.00
1 1916-25 STEERING WHEEL RIM 25.00 25.00
2 IRON STEERING WHEEL SPIDERS 25.00 50.00
5 FORMED STEERING WHEEL SPIDERS 10.00 50.00
4 STEERING COLUMN SUPPORT BRACKETS 10.00 40.00
1 THROTTLE ARM 5.00 5.00
1 SPARK ARM 5.00 5.00
1 EARLY STEERING SUPPORT ARM 10.00 10.00
MISC. STEERING COLUMN HARDWARE 10.00 10.00
11 STEERING WHEEL NUTS 3.00 33.00
5 1915-17 STEERING COLUMN 25.00 125.00
TO FRAME BRACKETS
3 1917-25 STEERING COLUMN 25.00 76.00
TO FRAME BRACKETS
2 1926-27 STEERING COLUMN 25.00 50.00
TO FRAME BRACKET
14 TRUCK STEERING COLUMN 25.00 350.00
TO FRAME BRACKETS
26 STEERING BRACKET MOUNTING BOLTS 3.00 78.00
9 PITMAN ARMS 20.00 180.00
26 STEERING MOUNTING BOLTS 1.00 20.00
11 SETS 4/1 GEARS 25.00 275.00
3 SETS 4/1 STERRING PINION GEARS 10.00 30.00
2 SET 5/1 STEERING GEARS 25.00 50.00
7 SETS 5/1 STEERING PINION GEARS 10.00 70.00
5 STEERING GEAR BOXES 10.00 50.00
7 TOP COVERS 10.00 70.00
14 STEERING QUADRANTS 5.00 70.00
1 THROTTLE SHAFT ARMS 5.00 5.00
1 SPARK SHAFT ARMS 5.00 5.00
TOTAL 4,932.00
TOP
27 TOP SOCKET ARMS, VARIOUS YEARS 5.00 135.00
1 PAIR 23-25 TOP REST SUPPORT BRACKETS 20.00 20.00
1 PAIR TOP REAR ARMS AND SADDLES 25.00 25.00
13 TOP PROP NUTS 1.00 13.00
14 TOP STRAP HOOKS AND BUCKLES 5.00 70.00
3 TOP SADDLE SETS 25.00 75.00
2 PAIR REAR TOP LEATHER AND HARDWARE 10.00 20.00
5 MISC TOP IRON BRACKETS 10.00 50.00
2 PAIR 1916-22 FRONT TOP IRON BRACKETS 25.00 50.00
7.5 PAIR 1923-25 FRONT TOP IRON BRACKETS 25.00 187.50
2 PAIR 1916-22 ROADSTER FRONT 25,00 50.00
TOP IRON BRACKETS
8.5 PAIR 1923-25 TOURINJG REAR 25.00 212.50
TOP IRON BRACKETS
2.5 PAIR 1913-15 FRONT TOURING 25.00 62.50
TOP MOUNTING BRACKETS
1.5 PAIR REAR TOURING TOP 25.00 37.50
MOUNTING BRACKETS
1 PAIR 1916-22 ROADSTER REAR 25.00 25.00
17 1916-22 TOURING FRONT TOP 25.00 425.00
MOUNTING BRACKETS
6 1916-22 TOURING REAR TOP 25.00 150.00
MOUNTING BRACKETS
30 FOOTMAN LOOPS 5.00 150.00
6 PAIR FIGURE 8 & TOP HOOKS 5.00 30.00
TOTAL
1,788.00
WINDSHIELD
# 1 1915 WINDSHIELD 150.00 150.00
3 1913-14 WINDSHIELD HALF FRAMES 25.00 75.00
7 1916-22 WINDSHIELD HALF FRAMES 25.00 175.00
5 1923-25 WINDSHIELD HALF FRAMES 25.00 125.00
MISC WINDSHIELD PARTS 30.00
TOTAL 555.00
SPEEDOMETER AND HORN
1 SPEEDO PARTS 5.00
12 HORN BRACKETS 5.00 60.00
7 HORN PARTS 10.00 70.00
18 HORN BUTTONS AND PARTS 5.00 90.00
TOTAL 225.00
HEADLIGHTS, TAILIGHTS, SPOT LIGHTS AND MIRRORS
15 PAIR 1916-25 HEADLIGHTS 75.00 1,125.00
1 PAIR 1916-25 HEADLIGHTS WITH SEAL BEAMS 75.00 75.00
3 BRASS HEADLIGHT RIMS 10.00 30.00
1 CHROME HEADLIGHT RIM 10.00 10.00
10 HEADLIGHT GLASS LENS 10.00 100.00
17 REFLECTORS 5.00 85.00
MISC LIGHT SOCKETS
MISC HEADLIGHT BULBS 7.00
18 DASHLIGHTS AND PARTS 3.00 54.00
5 RED REFLECTORS 3.00 15.00
8 STOPLIGHT SWITCHES 1.00 8.00
7 HEADLIGHT SWITCHES 1.00 7.00
1 STOP LIGHT 25.00 25.00
2 STOPLIGHT BEZELS AND FRAMES 10.00 20.00
2 SPOTLIGHTS 25.00 50.00
3 SPOTLIGHT PARTS 10.00 30.00
1 MIRROR 5.00 5.00
TOTAL 1,646.00
SIDE AND TAILLIGHT PARTS
6 TOPS 3.00 18.00
5 CHIMNEYS 3.00 15.00
3 CHIMNEY HOUSINGS 3.00 9.00
10 REFLECTORS 5.00 50.00
10 BODIES 8.00 80.00
8 DOORS 10.00 80.00
2 GLASS 10.00 20.00
3 BURNERS 5.00 15.00
2 BOTTOMS 8.00 16.00
TOTAL 303.00
IGNITION
2 MASTER VIBRATOR COILS 10.00 20.00
# 112 COILS 5.00 560.00
1 BOX OF COIL PARTS, NUTS AND BOLTS 10.00
66 TIMER ROLLERS 4.00 264.00
25 EARLY TIMER ROLLERS, BRASS 5.00 125.00
6B TIMER NUTS 1.00 6.00
33 TIMERS 5.00 165.00
31 TIMER SHIELDS 1.00 31.00
6 TIMER SPRINGS 1.00 6.00
14 EARLY TIMER SPRING BOLTS 1.00 14.00
4 LATE TIMER SPRING BOLTS 1.00 4.00
13 DISTRIBUTORS 25.00 325.00
6 DISTRIBUTOR SHAFTS 5.00 30.00
3 DISTRIBUTOR COILS 5.00 15.00
1 BOX OF DISTRIBUTOR SHAFTS, 25.00 25.00
7 DISTRIBUTOR HEADS 1.00 7.00
5 SETS DISTRIBUTOR GEARS AND NUTS 10.00 50.00
2 DISTRIBUTOR ROTORS 3.00 6.00
1 1914 COIL BOX 35.00 35.00
7 1915-19 COIL BOX 25.00 175.00
18 1919-25 COIL BOXES 10.00 180.00
2 1919-25 COIL BOX LIDS 10.00 20.00
1 FORDSON COIL BOX 10.00 10.00
9 1926-27 COIL BOXES 10.00 90.00
1 1926-27 COIL BOX LID 20.00 20.00
4 COIL BOX WOOD 5.00 20.00
14 IGNITION SWITCH PLATE 1.00 5.00
5 1926-27 IGNITION SWITCH PLATES AND PARTS 5.00 25.00
1 1919 IGNITION SWITCH 10.00 10.00
1 ACCESSORY IGNITION SWITCH 10.00 10.00
BOX OF IGNITION SWITCH PARTS 20.00 20.00
1 AMPMETER MOUNTING BRACKET 5.00 5.00
1 BOX OF ORIGINAL WIRING LOOMS 5.00 5.00
5 TERMINAL WIRE BLOCKS 10.00 50.00
30 WIRING CLAMPS 1.00 30.00
1 BOX OF 40 HEADLIGHT AND TAILLIGHT 25.00 25.00
SOCKETS AND HARDWARE
TOTAL 2,398.00
TRUCK RUCKSTELL
BOX OF TRUCK RUCKSTELL PARTS, NO HOUSING 100.00 100.00
MODEL A AND V8
7 MODEL A BENDIX 10.00 70.00
19 MODEL A AND EARLY V8 FRONT HUBS 10.00 190.00
12 MODEL A AND EARLY V8 REAR HUBS AND 10.00 120.00
BRAKE DRUMS
5 MODEL A AND EARLY V8 REAR BRAKE DRUMS 5.00 25.00
1 MODEL A HORN 45.00 45.00
2 MODEL A SHIFTER ARMS 10.00 20.00
1 FRONT SPINDLE 10.00 10.00
1 FAN 10.00 10.00
1 MODEL A WIRE WHEEL 25.00 25.00
1 MODEL A TRANSMISSION SHIFT LEVER 10.00 10.00
3 EARLY V8 WIRE WHEELS 25.00 75.00
1 EARLY V8 TIRE CARRIER 50.00 50.00
2 MODEL A TAILLIGHT SUPPORT ARMS 25.00 50.00
TOTAL 700.00
MISC. PARTS
18 SHELVING UNITS 25.00 450.00
2 TRUCK REAR SPRINGS 25.00 25.00
2 TIRE PUMP WOOD HANDLES 5.00 10.00
7 PAIR HASSLER SHOCKS AND MISC PARTS 50.00
3 PAIR ACCESSORY REAR SPRING HANGERS 10.00 30.00
TOTAL 565.00
GRAND TOTAL $161,514.00
ASKING $ 25,000.00
WHAT YOU PAY
MOTORS AND BLOCKS
RODS, GOOD BABBITT
MAIN BEARING BOLTS
AND HORSE SHOES
AND HORSE SHOES
CORNER BRACKETS
CRANK PULLEYS
TOTAL 23,282.50
TRANSMISSIONS
TOTAL 3900.00
TRANSMISSION PARTS
TOTAL 30,568.00
TRANSMISSION COVERS
PLATES (16-27)
TOTAL 2,273.00
STARTERS
STARTER PARTS
TOTAL 338.00
BENDIX
TOTAL 3,093.00
STARTER SWITCH
TOTAL 12.00
GENERATORS
TOTAL 4,900.00
GENERATOR PARTS
TOTAL 793.00
FANS
TOTAL 2,098.00
TOTAL 1,044.00
MUFFLERS
TOTAL 131.00
CARBURETORS
7 CHOKES 5.00 35.00
CONTROL RODS
TOTAL 4,382.00
FRAME
FRAME PARTS
MOUNTING BRACKETS
MOUNTING BRACKETS
MOUNTING BRACKETS
TOTAL 1,907.50
GAS TANK
TOTAL 1,037.50
FRONT AXLE
AND SPINDLES
SPINDLES OR PERCHES
TOTAL 7,980.50
SPRINGS
TOTAL 2,620.00
DRIVE SHAFTS
TOTAL 6,938.00
DRIVE SHAFT
OUT DRIVE SHAFTS
DRIVE SHAFTS
OUT DRIVE SHAFT
TOTAL 4,500.00
REAR AXLE PARTS
AND RING GEAR
NEED REPAIR
BRAKE SHOES
TOTAL 25,239.50
SHACKLES
TOTAL 2,869.00
WHEELS
GOOD WOOD
TOTAL 4,542.00
3 DASH 10.00 30.00
TOTAL 2,475.00
HOODS
TOTAL 365.00
RADIATORS
TOTAL 585.00
LIGHT BRACKETS
LICENCE BRACKETS
TOTAL 2,147.50
STEERING
TO FRAME BRACKETS
TO FRAME BRACKETS
TO FRAME BRACKET
TO FRAME BRACKETS
TOTAL 4,932.00
TOP
TOP IRON BRACKETS
TOP IRON BRACKETS
MOUNTING BRACKETS
MOUNTING BRACKETS
MOUNTING BRACKETS
TOTAL
1,788.00
WINDSHIELD
TOTAL 555.00
1 SPEEDO PARTS 5.00
TOTAL 225.00
MISC LIGHT SOCKETS
1 MIRROR 5.00 5.00
TOTAL 1,646.00
6 TOPS 3.00 18.00
8 DOORS 10.00 80.00
2 GLASS 10.00 20.00
TOTAL 303.00
IGNITION
TOTAL 2,398.00
TRUCK RUCKSTELL
MODEL A AND V8
BRAKE DRUMS
1 FAN 10.00 10.00
TOTAL 700.00
MISC. PARTS
TOTAL 565.00
ASKING $ 25,000.00
- MTFCA Number: 227
Re: 55 YEAR COLLECTION MODEL T FORD PARTS
WELL I TRIED. I MANUALLY FIXED THE FORMATTING OF THE PARTS LIST AND IT STILL WILL NOT PRINT IT CORRECTLY. I ALSO TRIED TO MANUALLY LOAD EVERY PICTUTRE BUT IT WOULD NOT TAKE THEM ALL. GUESS MY POST IS TOO LARGE, JUST LIKE MY PARTS COLLECTION! , SORRY
- MTFCA Number: 227
where is my new home?
- First Name: Tony
- Last Name: Bowker
- MTFCA Number: 32
Re: 55 YEAR COLLECTION MODEL T FORD PARTSGlen
Glen, you are limited to five pictures for each post. If you want more, just add another post on the same thread.
Thanks for the visit yesterday
Tony Bowker
La Mesa, California
La Mesa, California
- MTFCA Number: 227
Thanks tony
- First Name: Charles
- Last Name: Kennedy
- * REQUIRED* Type and Year of Model Ts owned: 1915 Ford Model T Canadian Touring Car
I sent you an email!
Hey, I could be interested be interested (might get in alot of trouble)
Give me an email charlesgregorykennedy at gmail dot com so we can talk!
thanks
Charles
thanks
Charles
- MTFCA Number: 227
Charles, My E-Mail is chaffinsgarage@pacbell.net. Just added another $30,000,00 in parts. Price is still the same. adding another $2,000.00 today. Price includes all the shelving seen. Great deal. Less than sixteen cents on the dollar. Great demand for parts on the forum. You won't have trouble getting your money back soon and still have a pile of parts. My son, Mark bought a house with money he made selling parts. Glen
- First Name: Dick
- Last Name: Cruickshank
- * REQUIRED* Type and Year of Model Ts owned: 1912 Depot Hack, 1916 Touring
Do you still have the brass radiator? Is it a 1916? Is it a flat tube? Is it usable or need to be recored? Could you send picture? Dick C.
- First Name: Jimmie
- Last Name: Rodgers
- * REQUIRED* Type and Year of Model Ts owned: 1926 Tudor, 1919 Roadster
Hi,
I am finishing an 8 year project. a 1919 Roadster.
All I need to finish it is the complete set of Top Irons and the Wood Bows.
I have the brackets that mount the bows to the body.
Do you have what I need? I live in Michigan and pick them up if you are fairly close.
Other wise, do you have any idea what shipping cost would be?
My cell # is, 213-250-5346 My email is jimmieclint@gmail.com
Thank you for your attention to my inquiry!
Jimmie
Jimmie
- First Name: Chuck
- Last Name: Griffin
- * REQUIRED* Type and Year of Model Ts owned: 1925 Tudor Sedan
- MTFCA Number: 31570
$25,000 for the entire collection,Is that correct?
- First Name: Alan
- Last Name: Purvis
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster
Sir, I just found this forum and I'm looking for a 1927 T Roadster driver's side door latch striker. If you have one I could really use it. I'm usually on the Ford Barn or the HAMB and I've had no luck at either place.
Thank you,
Alan Purvis
Thank you,
Alan Purvis
- First Name: David
- Last Name: Weeks
I need a complete front and rear axle for a 1915 thru 1925 T
