I am in need of a NH side drain carb that is NOT packed with rust and totally eaten up...I already have one of those!
In actuallity, I can reuse the body, but really need a good bowl with drain body installed
If you have something you believe I can use, I'd appreciate hearing from you.
thank you.
WTB - NH side drain carb or just a good bowl
Topic author - Posts: 6435
NH Full Flow Float Valves
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Re: WTB - NH side drain carb or just a good bowl
Scott please send me a picture.
- First Name: Bill
- Last Name: Crosby
- * REQUIRED* Type and Year of Model Ts owned: 1916 Touring, 1920 Coupe, 1926 RPU, 1927 RPU, 25 speedster project
Scott I have a few extra's $30 to your door. Bill
Hi Bill
I am sending you an email...
- First Name: Bill
- Last Name: Crosby
Scott, This is a nice side drain NH bole with surface rust and no pits. It will need a good cleaning. The drain valve Is brass and moves freely.
Bill
Bill
