Front pan mount
Posted: Sat Feb 10, 2024 4:34 pm
by Dollisdad
I need the piece that lays into the front spring mount and the hand crank passes thru it. It is a casting riveted to the nose of the pan. It can be broken. Doesn’t matter what year. Also need a set of 11-12 hub caps. Nasty and tarnished please. Thanks.
Re: Front pan mount
Posted: Sun Feb 11, 2024 1:21 pm
by FATMAN
Are you talking about the support that rivets to the pan, if so I have some,Bob
Re: Front pan mount
Posted: Mon Feb 12, 2024 12:36 am
by Dollisdad
This is what I’m looking for.
Re: Front pan mount
Posted: Mon Feb 12, 2024 6:59 am
by Karl Von Neumann
There's 2 different styles you might want to specify
Re: Front pan mount
Posted: Mon Feb 12, 2024 8:39 am
by Dollisdad
In my first post, I said it doesn’t matter what year. So to be clear it makes no difference if it is for an early narrow nose pan or the latter pug nose pan. Either one will work. Thanks Tom
Re: Front pan mount
Posted: Mon Feb 12, 2024 10:20 am
I sent an eMail and also a PM with Pictures
Just realized that your looking fo imperfect 11-12 hub caps. think i have 3 or 4. will check tuesday
