WTB working brass sediment bulb
Posted: Wed Feb 28, 2024 8:56 pm
by hull 433
If anyone has an original brass sediment bulb in working order, and seats with the gas line facing forward, please let me know.
Re: WTB working brass sediment bulb
Posted: Wed Feb 28, 2024 9:10 pm
by Allan
Stan, you might be asking the impossible to some extent. The sediment bulbs are on a taper thread. Where they end up oriented is anyone's guess. It depends on the thread wear in both the sediment bulb and the fitting in your tank. You will most likely have to make an adjustment in whatever is offered.
Posted: Thu Feb 29, 2024 3:03 am
by Mark Gregush
Posted: Thu Feb 29, 2024 7:48 am
by Karl Von Neumann
I agree with Allen. It's a tapered pipe thread on the end they. Wear your kinda stuck with what you got as far as position. The bowl itself usually doesn't go bad it's the valve that's bad which is fixable I posted a group of sediment bowl parts ill see if any are brass
Posted: Thu Feb 29, 2024 1:49 pm
by hull 433
Allan, I agree with you too. It works fine, it just seats out of alignment. I might just keep it as is - it's not too far out of alignment and everything else is in working order. At 108 years, probably adds a bit of character.
Posted: Thu Feb 29, 2024 2:11 pm
by Layden Butler
Just use pipe thread sealant (NOT teflon tape) and screw it in until it is aligned to where you want it but will not go another full turn around!
Always worked for me for the past half century.
Posted: Thu Feb 29, 2024 4:28 pm
by keen25
Does this look like the one?
Posted: Thu Feb 29, 2024 4:41 pm
by RajoRacer
Snyder's new repros are quite nice - we're lucky we can even get a new one !
Posted: Fri Mar 01, 2024 2:18 am
by Allan
That's the one Eric, but yours has a spurious drain cock. With the hex screwing up in close contact with the bulb like that, the thread may have been re-tapped to a parallel thread for that petcock.
