fordor door hinges 1926
Posted: Thu Mar 07, 2024 10:46 am
I need the top and bottom door hinges. Are they the same for each door just flipped over.These are for the left front that I need, but the right rear door seems to be the same. The hole the pin fits in is 1.2 " od. I have found some that were 5/8 " od that will not fit.
