FS NEW ASSEMBLED RUCKSTELL AXLE
Posted: Thu Mar 07, 2024 4:57 pm
by Mark Chaffin
I built this Ruckstell for a project I am no longer pursuing. Specifics are as follows:
* Complete new Ruckstell kit (26/27)
* New axle shafts, NOS axle gears, ring gear, bearings, sleeves, etc.
* Shortened driveshaft tube and radius rods for Layne Warford. New driveshaft, bearings, bushings, and 12 tooth pinion.
*Dan McEachern juice brakes and drums.
*New wire wheel outer hubs with new studs installed.
*New 26/27 inner wire wheel safety hubs.
*Lowered re-arched rear spring assembly with reversed eyes and new shackles included.
Price is $5,000. Pick up preferred. Mark Chaffin (951) 805-0928
20240307_093659.jpg[/attachment [attachment=0]20240307_093709.jpg
Re: FS NEW ASSEMBLED RUCKSTELL AXLE
Posted: Sat Mar 09, 2024 12:06 am
by Mark Chaffin
Quick list of what I have in it.
26/27 new Ruckstell kit 3,200.
New Axles $200.
Nos Axle Gears $100
New Shortened driveshaft $150.
Shortened Driveshaft Tube $100.
Tapered Bearing DS Spool $150.
New Ring and 12 Tooth Pinion $500.
New 26/27 Rear Hubs $600.
New Safety Hubs $550.
McEachern Hydraulic Brakes and Drums $1,000.
New Rear Shackles $75.
Reverse Eye Rear Spring Re-arched $150.
Much more in parts than the asking price. Assembled and ready to install.
Posted: Mon Mar 18, 2024 11:16 pm
by Mark Chaffin
Reduced to $5,000. Got over $6,500 invested in new parts alone. Not including labor to assemble.
Posted: Mon Jun 10, 2024 11:21 am
by Mark Chaffin
Still available.
Posted: Mon Jun 10, 2024 10:51 pm
by blauvelt
Did you have a local shop reverse the main spring eye? Or did you find elsewhere?
Posted: Tue Jun 11, 2024 9:35 am
by Mark Chaffin
The reversed main leaf was purchased.
