Sherman Sure Fire Twin Plug Head
Topic author - Posts: 80
- First Name: Antonio
- Last Name: Piery
- * REQUIRED* Type and Year of Model Ts owned: some very old cars
I have unused Sherman Sure Fire twin plug head, great for a speedster project, or other T powered cars. $700 plus shipping
- First Name: Chad
- Last Name: Azevedo
- * REQUIRED* Type and Year of Model Ts owned: 1926 Boattail speedster, 1912 Tourabout project, 1927 Speedster (build)
Re: Sherman Sure Fire Twin Plug Head
Will you be at the endurance run?
- Last Name: Piery
No I wont be, but will be at the LA roadster show on fathers day in June and the Long Beach Model T swap met in July
- First Name: Robert
- Last Name: Weitzel
- * REQUIRED* Type and Year of Model Ts owned: 27 coupe,23 touring 14 speedster WILD CHERRY 2 1909 touring 27 roaster
- MTFCA Number: 22631
Trade ya for some. American wheel caps , buffalo caps
- Last Name: Piery
Thanks for the offer, but at this time I want to sell this.
- First Name: Mike
- Last Name: Lebsack
- * REQUIRED* Type and Year of Model Ts owned: 11Torpedo, 11 Roadster, 13 Touring, 14 Roadster, 14 Touring
- Board Member Since: 2008
Hi.
What is the large hole in the rear center for? Mike
- Last Name: bevardos
- * REQUIRED* Type and Year of Model Ts owned: Roadster, Coupe, pickup truck, 2-door
mike, its to add a temp sensor ---if wanted . John
- First Name: Chad
Temp sensor or zinc electrode to prevent electrolysis
- First Name: DAN
- Last Name: MCEACHERN
Interesting that the plugs are offset- I've seen a lot of Sherman heads and I don't recall ever seeing a twin spark with the holes offset like this one.
- First Name: Kevin
- Last Name: Matthiesen
- * REQUIRED* Type and Year of Model Ts owned: 1926 Coupe, 1921 speedster, 1925 TT, 1916 Exp
- MTFCA Number: 11598
Dan, I noticed the offset spark plugs also. The plugs more back from the ports are intake, could it be for a little more cooling in the head to help with the incoming mixture not to detonate ? With the pipe plug hole at the back top of the head I have seen a cooling pipe added that runs to the front cooing outlet to help promote cooling flow in the back of the engine.
- First Name: Chad
My money would be on larger intake valves and the desire to place the plug directly over the valve.
- First Name: Kevin
Yes Chadwick you are correct, the offset would help with bigger intake valves and port work. Have a good run with your mom's speedster on Sunday.
- First Name: Roger
- Last Name: Harmon
- MTFCA Number: 16412
So; how much larger can you go with intake and exhaust valves?
- First Name: Roger
- Last Name: Harmon
And where can I read more about it?
- MTFCA Number: 52564
Roger you might want to move your question over to the forum. You would have a better chance of getting an answer there, more eyes.
1920 Dodge touring
1920 Dodge touring
- Last Name: Piery
Thats a nice head talk to jerrt sherman junior on oversize valves chad is right
