FS Ed Winfield 5H Sidedraft Racing Carburetor (SOLD)
Posted: Thu Apr 25, 2024 4:45 pm
Original Ed Winfield 5H side draft racing carburetor. The rarest of them all. Very simple carburetor. Good clean rebuildable condition, complete with barrel float. Throttle barrel nice, turns smooth in bore. Brass throttle arm will need worn oval hole on the end brazed and re-drilled back to shape for desired throttle linkage. Cast aluminum body, no pot metal. 2-11/16 between mounting holes, 1-3/8 opening. Included two float needle seats, one modified, one unmodified so the float shut-off needle can be fitted, sealed and reset.(Float needle design similar to Stromberg OF) Includes brass matching port adapter for Frontenac? 625 includes shipping.
