1912 Holley Carburetor (SOLD)
Posted: Mon May 06, 2024 5:16 pm
by ThreePedalTapDancer
Rare 1912 year Holley H1 4500 carburetor. This is a very clean and complete carburetor. Needs to be rebuilt. Includes the float, all internals, and a CRACK FREE brass bowl. It even has the correct original fuel line fitting. The internal venturi is still solid. Needs standard rebuild, including re-bushing the throttle shaft, new or modern float, and adding a new choke return spring. Very hard to find, impossible to find with an uncracked original bowl. 375 includes shipping.
Re: 1912 Holley Carburetor
Posted: Wed May 08, 2024 10:03 pm
Very hard to find.
Posted: Tue May 21, 2024 3:44 pm
Ready to restore.
Posted: Tue Jun 04, 2024 10:51 pm
To the top
Posted: Wed Jun 05, 2024 8:42 am
by Don ellis
just curious, what did you use to clean that thing with and get that finish on the cast body?
Posted: Thu Jun 06, 2024 8:12 pm
by JTT3
Don LOL, I was thinking the same thing!
Posted: Fri Jun 07, 2024 12:11 pm
by BRENT in 10-uh-C
Don ellis wrote: ↑Wed Jun 05, 2024 8:42 am
I can't answer for the Seller but I get similar results with wet blasting. The proper term is Vapor Honing, and if you Google it, there are several YouTube videos out there that show how to convert a regular Harbor Freight Blast Cabinet into a Vapor Honing Cabinet. I just use crushed glass for media. As for the bowl, likely a little White Rouge and a Buffer will polish that right up.
Posted: Fri Jun 07, 2024 12:25 pm
by Dan Hatch
Didn’t Stan post something about how he got that look with his ultrasound tank a few years ago.
Posted: Fri Jun 07, 2024 4:44 pm
by BRENT in 10-uh-C
Dan Hatch wrote: ↑Fri Jun 07, 2024 12:25 pm
Dan, I have an Vevor Ultrasonic tank that I generally use a degreaser in such as Awesome or Simple Green. It will do a great job of getting it degreased however it would take a special chemical to make it look like that. You really should get or make yourself a Vapor Hone. Use it to clean bearing caps that have been heated, tinned and poured. It won't imbed the media when you take the flash rust off. Then line bore and away you go. Valves that you are removing carbon from is another use. It won't scratch or pit the stems.
