WTB one wood coil.
Posted: Tue Jul 02, 2024 11:06 am
by Tim D
WTB one rebuilt wood coil or one that just needs a cap. In Wisconsin. Thanks
Re: WTB one wood coil.
Posted: Tue Jul 02, 2024 11:50 am
by TWrenn
Contact Brent Mize or Ron Patterson
Posted: Tue Jul 02, 2024 12:58 pm
by Karl Von Neumann
Tim I've got a big box of coils here some work some don't pleasant prairie area
Posted: Tue Jul 02, 2024 3:22 pm
by Tim D
thanks have one coming from Adam.
Posted: Sat Sep 14, 2024 7:01 pm
by Kajtek1
Can you measure the resistance on side prongs?
I bought couple of coils on ebay and they show open circuit, what means bad wires.
I can replace condenser, but not the coil.
Posted: Mon Sep 16, 2024 11:02 am
by Karl Von Neumann
I sold all the good coils I had and just got in another small batch but haven't had time to go thru them yet
Posted: Mon Sep 16, 2024 12:49 pm
by J1MGOLDEN
Another give away for the coil is whether the slide off side has two small nails to hold it in place or a staple.
The ones with the nails have Ford at the top or perhaps if older, in the center of the other side.
I have found coils that make sparks on the Hand Crank Coil Tester with no sparks showing on the StroboSpark Coil Tester.
They always seem to be the ones with the staples and measuring the secondary winding with an ohm meter will show about 2,8000 Ohms or a little less, and they will work in a Model T Coil Box, with a little less hot spark value..
The ones marked Ford all seem to be right at the 3,300 Ohms that appear to be correct and they will always produce the 2,500 Volts that the StroboSpark has to read to light the three bars.
