WTB: Original Ford Rear Axle sleeve puller
Posted: Thu Jul 04, 2024 1:43 pm
by michaelb2296
Not looking for modern junk. A real rear axle sleeve puller
Please. Thank you!
Michael
Re: WTB: Original Ford sleeve puller
Posted: Thu Jul 04, 2024 2:20 pm
Not looking for modern junk. A real sleeve puller
Please. Thank you!
Michael-
Drive shaft spool or rear axle sleeve? Don't have but pictures help
I have a new style rear axle sleeve puller, must be an earlier version, that has a spring behind the button than the newer one doesn't have. Once the button is in the hole in the sleeve it isn't going to slide out.
Drive shaft listed a year ago viewtopic.php?t=34632
drive shaft sleeve puller.jpeg (60.04 KiB) Viewed 2301 times
Rear axle sleeve puller https://www.mtfca.com/discus/messages/8 ... 1258856981
Re: WTB: Original Ford Rear Axle sleeve puller
Posted: Thu Jul 04, 2024 5:19 pm
by michaelb2296
Rear Axle sleeve puller. My mistake for not being clear.
Posted: Fri Jul 05, 2024 2:23 am
by KimDobbins
The Steven's rear axle sleeve remover is the one to get! Highly recommended.
Posted: Fri Jul 05, 2024 5:43 am
by michaelb2296
Thanks for the heads up.
Posted: Fri Jul 05, 2024 8:45 am
Does the Stevens tool remove the sleeve while the axle shaft is still in place, or must it be an empty housing?
Posted: Fri Jul 05, 2024 4:33 pm
by TrentB
The Stevens rear axle sleeve puller is hollow in the center, so it can be used with the axle shafts still in place.
Posted: Fri Jul 05, 2024 8:04 pm
The one Dave Huson posted is the ducks guts. You can use it with the axle still in the housing. The hose clip shown is a later addition, probably to make up for the loss of the spring used to hold the little register in the sleeve hole. I don't have one, nor do have the TT one I passed on a few years back!
Posted: Tue Jul 16, 2024 5:46 pm
by michaelb2296
Still looking
Posted: Tue Jul 16, 2024 6:19 pm
by Dan Hatch
Scott Conger reproduced some a few years ago and they are great. He said he would not do it again, but maybe if you ask real nice he might be talked into it. Dan
Posted: Tue Jul 16, 2024 6:50 pm
by George House
I have an original dealership type rear axle sleeve puller I’d sell. Let me go out to the barn and take a picture of it.
Posted: Tue Jul 16, 2024 7:09 pm
by George House
Here it is Michael. If this is what you’re looking for, email me. I’ve used it over half a century, its heavy duty and in good shape. Can also be used when axle is in the housing.
Posted: Thu Jul 18, 2024 5:00 pm
by George House
SOLD to Michael. Thank you sir and thanks MTFCA 😀
