WTB, Fan Shaft grease cup
Posted: Mon Aug 05, 2024 12:15 pm
These parts are not listed separately in the parts book. I want to stipulate the entire assembly is solid brass and screws onto the fan shaft. Don't want a reproduction. Need the grease cup and the nut it screws onto.
Re: WTB, Fan Shaft grease cup
Posted: Mon Aug 05, 2024 9:55 pm
by QuestQuencher
Just clarify that you need the whole assembly in solid brass, including the grease cup and the nut, and that you're looking for original parts, not reproductions. That should help narrow down your search.
Posted: Mon Aug 05, 2024 10:22 pm
Can't say I've ever seen a brass nut one Larry - I've got original steel ones.
Posted: Tue Aug 06, 2024 10:57 am
by Karl Von Neumann
Never seen a brass one either only steel grease cups
Posted: Tue Aug 06, 2024 12:25 pm
Original Smith wrote: ↑Mon Aug 05, 2024 12:15 pm
Understand that your looking for originals not repros.
Just to confirm: when you say you want the entire assembly ... then... Need the grease cup & the nut it screws into. Did you mean the assembly (cup with nut) that screws onto the fan shaft end.
