New 09-10 fan blades
Posted: Thu Aug 22, 2024 10:26 am
by Larry Debaugh
Exact 09-10 fan blades die stamped with mounting holes. $140 for a set of 4 , postage $11 US , 09/10 blades have greater pitch than the later blades
, Lang’s will rivet the blades on your hub including the rivets for $30. Larry Debaugh 4103361728
Re: New 09-10 fan blades
Posted: Thu Aug 22, 2024 10:18 pm
Excellent job Larry. They are pressed much more deeply and with greater definition than the later ones. In my experience, they may run a little later, up to 1912, but others may know better.
Posted: Fri Aug 23, 2024 8:41 am
by Larry Debaugh
Thanks Allan, yes I think they were used into at least 11, but I have no documentation, I have several different examples of different definition and angle which I assume changed as Ford changed the coolant system capacity. Larry
Posted: Fri Aug 23, 2024 10:26 am
by Dave_Martin
Larry, Beautiful! Thank you for taking the time to reproduce these correctly.
Posted: Fri Aug 23, 2024 12:46 pm
by Larry Debaugh
Thanks, I was desperate… 3 10’s one blade! Lol
Posted: Wed Aug 28, 2024 10:15 am
by Larry Debaugh
9 sets sold , more still available… Larry
Posted: Sun Sep 08, 2024 10:50 am
by Larry Debaugh
12 sets sold …. Others still available
Posted: Sun Sep 08, 2024 12:00 pm
by Stephen_heatherly
Will these work on a later fan?
Stephen
Posted: Sun Sep 08, 2024 3:33 pm
by Larry Debaugh
Yes will work through the 20’s and move more air because of the increased pitch, I made them for the 9-11 because they were impossible to find… larry
Posted: Wed Sep 18, 2024 7:07 pm
by Larry Debaugh
Sets still available
