Commutator Rod Swivel F/S
Posted: Fri Aug 23, 2024 3:43 pm
I can supply a very limited number of the proper timer control rod swivels with nut for earlier Model Ts. They are NOS New Old Stock and there will be no more when these are gone. If you do not have a threaded rod, I will throw in ( until they run out) a later control rod that you could cut off the end and thread for the swivel. Priced at $45 each, domestic postage $10 per order. Let me know if you prefer bare iron or bright.
