NO LONGER NEEDED! WANTED TO PURCHASE - STEERING GEAR CASE/CUP 1926 COUPE
Posted: Sun Sep 15, 2024 10:53 am
by lirogo27
I am located in California. Willing to pick up locally if necessary. Looking for a 1926 Steering Gear Case/Cup. If it comes with cover, I am happy to purchase as set. Thank you. Lisa - Please contact me via the forum message center if you d have these items. Thank you!
Re: WANTED TO PURCHASE - STEERING GEAR CASE/CUP 1926 COUPE
Posted: Mon Sep 16, 2024 12:36 am
by modeltspaz
Lisa,
If you haven't already, try Mark Chaffin. He often has parts not advertised here on the forum.
Another source would be Lang's. They're a great bunch of people and are always very helpful. Like Chaffin's, they have a good selection of used parts, but you have to contact them by phone.
The third possible source would be Bob's in Loves Park, Ill. He has a very good selection of used parts.
Good luck,
Mike.
Posted: Mon Sep 16, 2024 9:32 am
lirogo27 wrote: ↑Sun Sep 15, 2024 10:53 am
lirogo27@aol.com
I should have one. Just bought a Barn load of parts & set aside some steering columns for parts. Will look later today. But if Mark has one take it.
Posted: Mon Sep 16, 2024 12:05 pm
by ModelT46
he will need one from a 1926-27 column.
Posted: Mon Sep 16, 2024 11:07 pm
by lirogo27
Frank - Let me know! In error, your reply got flagged and reported. Darel, Yes it is a 1926 coupe. Mike, Will ask Mr. Lang and Mr. Chaffin but if Frank has the parts I would be happy to work with him. Thank you
Posted: Tue Sep 17, 2024 3:46 pm
by lirogo27
TRDxB2 wrote: ↑Mon Sep 16, 2024 9:32 am
lirogo27@aol.com
Let me know! always happy to take it off your hands! Standing by! Lisa Goldberg. Also, if you have the bumpers, happy to buy the same. Thank you much! Lisa
Posted: Tue Sep 17, 2024 7:11 pm
lirogo27 wrote: ↑Mon Sep 16, 2024 11:07 pm
I pulled one out of storage. Need to disassemble, part out, the steering column. Will send you an eMail & if you respond I can send pictures.
The cup looks like its still nickle finish, gears look good & greasy, the cap is in question has barn dust/oil incrustation
Posted: Tue Sep 17, 2024 11:55 pm
by lirogo27
TRDxB2 wrote: ↑Tue Sep 17, 2024 7:11 pm
I sent you an email reply! standing by on the cup and cover. No need on steering column or gears. but let me know what works for you!
Posted: Thu Sep 19, 2024 7:47 am
by J1MGolden
The best way to get the part you need is to look the part up in a Ford Price List of Parts.
Then mention the correct part number in your ad.
That small book is worth the price!
There is no steering gear case cup listed in the book!
Does everyone but me know what part is required?
Then I have only been working with Model Ts for 42 years now!
One old gent told me I can learn something every day, if you pay close attention!
I'm guessing this might be a 3539-D Steering bracket with Bushing.
Posted: Thu Sep 19, 2024 9:27 pm
by jab35
The OP seems to have found the requested parts. FWIW, p/n 3507 is the "Steering gear internal gear and bushing", p/n 3504 is "steering gear cover", both parts used 09-26 according to1926 Ford parts list. P/n3539D is "steering gear bracket assembly" for coupe , roadster, tudoor and touring. jb
All from:
https://www.cimorelli.com/mtdl/1926/default.htm
Posted: Fri Sep 20, 2024 2:48 am
jab35 wrote: ↑Thu Sep 19, 2024 9:27 pm
All from:
You are correct on all accounts, part numbers and (Lisa) found that parts; being shipping Today, Friday. The knurling on the cover for 1926 is over the entire edge as opposed to the upper half of the edge
Posted: Fri Sep 20, 2024 11:13 am
by jab35
Glad it all worked out. jb
Posted: Fri Sep 20, 2024 2:11 pm
by J1MGolden
Case and cover would have been a better description.
Posted: Fri Sep 20, 2024 8:15 pm
by lirogo27
James - YES IT DID thanks to Frank. I am floored at how you folks support 'your own'. Truly very appreciative. Jim Golden - I was going to list part number from a retailer's current day sales catalogs but I did not think it would matter as part is no longer made allegedly. Jim has an excellent suggestion and i will locate a reprint copy of the ford list for future.
Jim Golden - JIM !!!!!!- I have sent PM's to you over past few days. Please contact me. You might remember - you sent me a few parts a year or two ago. I have a question for you and sent it via PM on the MTFCA site. THX@ Hope you are well. Lisa
Posted: Fri Sep 20, 2024 8:33 pm
by lirogo27
All from:
Yes but do not need the gears. I should have listed the parts #s but as I said, one is allegedly not made anymore so figured my own unique verbiage would do the trick! LOL. BTW -Replaced the gears recently. I need the other two items. Am thinking mine is worn too much internally causing gears to move and allow play in wheel
Posted: Mon Sep 23, 2024 8:32 pm
by lirogo27
All from:
yes 3507 and 3504 are the part numbers. One is still manufactured and one is not.
