Sold Le-Testophone musical horn
Posted: Thu Nov 28, 2024 7:29 pm
I have a Le-Testophone musical horn for sale. It is a Bulb type and has 4 separate length horns. I have not seen any of these in a long time on the old cars. They were a very popular accessory with the brass era guys for a long time. This horn is in pretty nice condition. I tried it when I first got it with a bulb I had then. The slide valve worked, and I got all four horns to sound off. Each squeeze of the bulb sounds a horn and then rotates the valve to the next horn, and so on till all 4 horns have been sounded and then starts over with the first horn again. This horn will need to have the slide valve at least cleaned and oiled. The dust cap on the end of the slide valve is missing but it is just a simple metal cap that should be easy to find or make. The mounting bracket works as-is but could be made to look a little nicer with a little cleanup and make the brazing look a little better. There are a few small dings in the horns but nothing major. All the brass is solid and does not have any stress cracks. Overall, it is a nice restorable horn that very few people have. Im cleaning out the shop of projects I no longer need, So it's time for another person to be the new caretaker.
Ill take 125.00 plus 18.40 flat rate shipping = 143.40 total due. It will be well packed. I will ship International at actual shipping cost.
I accept pay pal, check, or money order for payment.
Please contact me at the info in the last photo. Do not use the message board as I may miss your message.
