1915 Centerdoor intake manifold
Posted: Fri Dec 13, 2024 1:00 am
by cchigaridas
I need a factory extended neck intake manifold for my 1915 Centerdood sedan. The gas tank was under the back seat and it starved going up hills without the long neck. Any help would be appreciated.
Re: 1915 Centerdoor intake manifold
Posted: Fri Dec 13, 2024 8:14 am
by Mark Gregush
Rare as hens teeth! This might work, not original but has a much longer neck. Don't know if he wants to sell.
https://www.facebook.com/photo/?fbid=92 ... 9581385548
The alterative might be to cut the down pipe and extend it.
Posted: Fri Dec 13, 2024 9:03 am
by Stephen1915
Here is a photo of what Chris is looking for-
Posted: Sat Dec 14, 2024 12:55 am
by Robert Kiefaber
Mark, good idea I have thought about doing that I need one as well.
Posted: Sat Dec 14, 2024 2:43 am
by KimDobbins
Hi Chris, i sold my 15 centerdoor years ago. The one on my car was the only long manifold ive ever seen, i hope you can scare one up. In the mean time, i think id section a piece from another one in. Best of luck to you.
Posted: Sat Dec 14, 2024 8:52 am
by Dan Hatch
Just a question, was this used on any other car?
Or was it 15 only? Thanks Dan
Posted: Sun Dec 15, 2024 7:09 am
by Wayne Sheldon
1915 only and center-door sedan only. Due to the low flat gasoline tank under the far back rear seat in only that one model that one year. Less than a thousand such cars were produced, and maybe a few extra manifolds? So likely very few such manifolds survive.
I would expect to cut and weld/braze pieces from a couple iron manifolds to approximate one. I have brazed a few iron intake manifolds for various special adaptions over the years. That iron brazes very well and makes a strong bond.
With a little effort, one could make one nearly identical to the photo Stephen shared that once painted would look and function nearly perfect.
Posted: Mon Dec 16, 2024 12:26 pm
by Mark Gregush
LOL think maybe someone is smoking the wishful thinking pipe!!
https://www.ebay.com/itm/405418719539?_ ... R4yO_If6ZA
