WTB Rain Gutter without Drip Edge
Posted: Sun Dec 15, 2024 4:45 pm
by adam13
Want to buy 2 rain gutters for firewall without the drip edge. Contact AJ or Mark Eyre through the forum.
Re: WTB Rain Gutter without Drip Edge
Posted: Sun Dec 15, 2024 5:08 pm
by RajoRacer
Please explain "w/o drop edge" - I have a wood firewall top gutter piece.
Posted: Mon Dec 16, 2024 5:53 am
by Allan
Our Canadian sourced cars with a wooden firewall came with thin [think tinplate] metal cover on the sides, from the relief for the hood hinge down to the bottom. This was nailed on and the hood lacing was nailed over the top of it. Are you looking for a similar piece to go across the top, without the rain gutter? I can't recall ever seeing one.
Posted: Tue Dec 17, 2024 6:10 pm
by Model T Mark
He took a picture last night but he has basketball till late each night this week so as soon as he can he will.
Posted: Wed Dec 18, 2024 12:01 pm
by adam13
Here is a picture of one. Sorry to all for slow responses as I’ve been very busy coaching and starting building a house this week. Thanks, AJ Eyre
Posted: Wed Dec 18, 2024 4:39 pm
by Allan
Adam, thanks for the photo. I have never seen the like. Perhaps you would have what you need by cutting the rain gutter off a later one. On our Canadian sourced cars there is a crescent shaped relief in the wooden firewall to accommodate the hood hinge rod. I can't see this in your photo. Our rain gutters terminate at this relief, and short separate sections finish off the firewall down each side.
Posted: Wed Dec 18, 2024 5:02 pm
by RajoRacer
This is what mine looks like.
Posted: Thu Dec 19, 2024 9:11 pm
by Mark Gregush
yup, parts book does show sides and top.
Posted: Thu Dec 19, 2024 11:29 pm
by Allan
The metal will shed water. It likely there to protect the edges of the wooden firewall/veneer from water ingress. On our Canadian cars the top cover with the rain gutter had holes drilled and the nails which held the welting also held the rain gutter piece in place, with the addition of a screw into the side of the piece at the centre under the hood centre hinge rod. The bits of tin on the lower sides were not drilled. The nails which hold the welting on also held the thin metal strip in place.
Posted: Sat Dec 21, 2024 9:57 am
by Jerry VanOoteghem
RajoRacer wrote: ↑Wed Dec 18, 2024 5:02 pm
Yes, but they're not all like that.
Posted: Sat Dec 21, 2024 10:02 am
Adam/Mark,
This piece was missing on my '21 Runabout. Most of them are, because they were made of a thin, cheap piece of tin and they simply rusted away. Good news is, however, they are made of a thin, cheap piece of tin! For my car, we used tin strip of the proper width, and just turned over the edges. The edges are fairly narrow, which also makes it easy to form. You could do it over a seperate form or possibly just form it in place, on the firewall.
It's in 3 pcs., correct? A top piece and two side pieces, with a gap in between to clear the hood hinges? (My car is not on-site to have a direct look, or take pictures.)
Posted: Sat Dec 21, 2024 10:44 am
by RajoRacer
Thanks for the additional info - not seen one without the gutter.
Posted: Sat Dec 21, 2024 11:48 am
by Mark Gregush
I should re phrase what I wrote, the parts book (1921) list them but does not show them. Also does not say gutter type or not. Unlike later, parts numbers didn't change by adding a letter after them like became the norm later.
Posted: Sat Dec 21, 2024 10:56 pm
by Allan
I would be taking up the one Steve has offered. The thing is more complicated than it looks. Because it is angled at the ends to follow the taper in the hood sides, it becomes three dimensional rather than just a flat piece with folded edges. The one he shows is a pressing, with the correct angled ends. It just needs the gutter cut of and that bit of centre bracket added. It is likely of somewhat heavier gauge metal than the tinplate side pieces.
Posted: Sun Dec 22, 2024 9:22 am
by RajoRacer
The center bracket is on the other side !
Posted: Sun Dec 22, 2024 11:05 am
Allan wrote: ↑Sat Dec 21, 2024 10:56 pm
Allan,
Is that how the gutterless trim piece was made on your car?
Good luck Adam.
