Complete U&J carburetor/manifold
Posted: Sat Dec 28, 2024 12:07 am
Rebuilt, and engine tested U&J carb with the correct manifold. This is the ultimate set-up for any T, easy to adjust, and provides the most power over all other aftermarket carbs (check out the late Stan Howe's posts). It has had the standard milling operation to accept a Holley G bowl and this one has the heavy brass bowl. You will need to fabricate a throttle rod. Asking $850.00 including shipping to cont. USA and Canada.
