WTB: Magneto drive coupling, ie 2 flanges with flexible disc between for tapered shaft magneto such as Bosch DU4
Posted: Thu Jan 16, 2025 5:58 pm
by rendo
WTB: Magneto drive coupling, ie 2 flanges with flexible disc between, for a tapered shaft magneto such as a Bosch DU4, etc.
Re: WTB: Magneto drive unit, ie 2 flanges with flexible disc between
Posted: Thu Jan 16, 2025 10:52 pm
by Mark Gregush
Are you looking for whole drive or just the couplings? If just the couplings might want to update your listing on what drive unit and magneto you are using. Also, if either are straight or tapered shafts.
Posted: Fri Jan 17, 2025 1:09 pm
by Kevin Pharis
A simpler option to manufacture is the MATCO cross drive style coupling. This was basically a pair of 1” diameter hubs that mount to each side, and a short length of fabric reinforced rubber hose clamped between. Very simple and low profile. Will try to dig up a pic…
Re: WTB: Magneto drive coupling, ie 2 flanges with flexible disc between for tapered shaft magneto such as Bosch DU4
Posted: Tue Feb 18, 2025 8:29 am
by babychadwick
Would a lovejoy coupling work?
