WTB Steven's front axle yoke resurfacing tool
Posted: Fri Jan 31, 2025 6:48 pm
by Jack Putnam, in Ohio
I am searching for the Stevens Front axle facing tool that is used
to reface the inside yoke surfaces. The inside surfaces of the front axle yoke wear and this tool is used to file them perpendicular to the king pin. Please contact me through the forum email. Thank you, Jack
Re: WTB Steven's front axle yoke resurfacing tool
Posted: Fri Jan 31, 2025 6:59 pm
by RGould1910
Heres the tool I use. Got the idea from Dan Hatch.
Posted: Fri Jan 31, 2025 9:09 pm
Richard, thank you for your reply. I am hoping to remake the original tool, I am not trying to repair an axle. I believe I made the Steven's tool you show in your picture
Posted: Fri Jan 31, 2025 9:26 pm
by Pep C Strebeck
Jack,
If you do make the tool for sale like your Reaming Fixture Frames, I will definitely buy one, not just saying' I'll even pre-pay. I use a reverse spot-facer and it works, but an original or quality reproduction would be very much appreciated. Here are a couple of photos from the Forum showing it in use (for those not in the know) and a link to a complete axle rebuild. As far as I know it is not shown in the Stevens catalog.
viewtopic.php?f=2&t=26080&p=200399&hili ... le#p200399
DB axle (16).JPG (69.17 KiB) Viewed 6508 times
DB axle (17).JPG (70.12 KiB) Viewed 6508 times
Posted: Sat Feb 01, 2025 12:40 am
by dobro1956
Jack. The photos posted above are my refacer. I may have the only one left ??. I have never seen another. I do not want to sell mine, but would consider a short term loan if it would help you getting them made. I use it fairly often so it can only be loaned for a short time. The main issue I see is the cutter is extremely hard. Properly making it would be the key to having a useable tool. It really does not "cut" as it re-faces but "scrapes" the surface smooth. It makes extremely fine shavings and must be cleaned very often as it's being used. The cam and the handle would also need to be very hard because they are under a lot of pressure when in use. But they probably are not as hard as the cutter. Send me a message if you want to discuss it.
Posted: Sun Feb 02, 2025 1:01 pm
by TrentB
No, there are at least two survivors. This one is NOS.
Posted: Sun Feb 02, 2025 4:52 pm
Trent: I have sent you an email . Jack
Posted: Fri Feb 07, 2025 12:50 pm
I'm still searching for this Steven's axle tool. Can anybody help me find one??
Posted: Fri Feb 07, 2025 1:27 pm
by speedytinc
Search "Used my rare Stevens front axle re-facer today"
Donnie Brown posted a dimensioned drawing of the tool you seek.
I reproduced one from it. Thanks Donnie.
If you reproduce parts, I would be interested in a cutter. I didn't get a proper hardening on mine.
Posted: Fri Feb 07, 2025 7:39 pm
by JTT3
John can’t you reharded the piece and then temper it again?
Posted: Fri Feb 07, 2025 8:10 pm
by speedytinc
I tried a second harden. Didnt take. I should have used a hardening tool steel. I used a chunk of axle.
Posted: Mon Feb 17, 2025 4:43 pm
I'm still searching for this tool.
Posted: Thu Mar 06, 2025 3:17 pm
Well the need continues as well as the search.
Still searching .
Posted: Sun Apr 06, 2025 5:15 pm
And the search continues. There must be a survivor available somewhere.
