1912 Holley H1 carburetor/sold
Posted: Wed Feb 26, 2025 2:23 pm
by Corey Walker
Completely disassembled and cleaned, viton tipped needle and seat conversion, new float, venturi, choke spring and spray needle, throttle shaft bushing installed and test run. $675 postpaid to continental USA email:
wlkma9@gmail.com
Re: 1912 Holley H1 carburetor
Posted: Wed Feb 26, 2025 2:28 pm
by Corey Walker
I can take off $100 if this is to be a spare or replacement for an existing H1 and you can use the inlet elbow assembly you have already. There are more H1’s than elbows and it takes only a minute to swap them from carb to carb.
