Full Flow Float Valves™ for NH, Vaporizer and Simmons (Wizard) - Back in stock!
Posted: Sun Mar 02, 2025 2:39 pm
by Scott_Conger
Cures rips, tears, snares, corns, callouses, and beats back bad breath
not really
but it WILL make your car go up steep hills even with a low gas tank, and make "vapor lock" a thing of the past. You will never encounter a "9 gallon hill" again, with a float valve that REALLY FLOWS. If you're really unsure if they work, just ask the guy who just passed you on your next tour, or one of the many many Forum users who have already taken the plunge.
I am the designer, the manufacturer, and sole source for these valves. Beware of imitations.
As always, INQUIRE VIA EMAIL THROUGH THE MTFCA WEBSITE - NOT MESSAGING
QUESTIONS ALMOST ALWAYS RESPONDED TO THE SAME DAY
Thank you
Re: Full Flow Float Valves™ for NH, Vaporizer and Simmons (Wizard) - Back in stock!
Posted: Mon Mar 03, 2025 3:29 am
by Dan Hatch
If you don’t have one in your NH, you better get one. Great product! Thanks for making it Scott.
Posted: Mon Mar 03, 2025 6:22 am
by Henry K. Lee
And just like that....., "The Grand Master of Micro Machining" pops out of his burrow to see if he is needed! Yes Scott your services are beyond needed and are a must! Rock On Brother!
The Recluse of "Dim Dar Hills in a Holler"
Posted: Mon Mar 03, 2025 12:51 pm
by Original Smith
I haven't had luck with these valves. I wonder if the additives in the California gasoline has something to do with it?
Posted: Mon Mar 03, 2025 2:46 pm
by TRDxB2
Looks like it
AI BOT
Specific gravity (SG) is a measurement of how dense an object or substance is compared to water, and it's used to determine if something will float or sink.
California gasoline typically has a slightly higher specific gravity compared to regular gasoline in other regions due to the mandatory addition of oxygenates like ethanol, which are slightly denser than the hydrocarbons in standard gasoline, resulting in a slightly heavier fuel mix; however, the overall difference in specific gravity is usually small and within the normal range for gasoline
Posted: Mon Mar 03, 2025 4:32 pm
by Scott_Conger
Smith has never purchased any valves from me.
Posted: Mon Mar 03, 2025 4:58 pm
by Henry K. Lee
Someone needs a bubble wrap re-enforced bandaid!
Posted: Mon Mar 03, 2025 8:53 pm
by Tmooreheadf
I have two of these valves in straight thru NH carbs and they work flawlessly. No longer run out of gas on a hill unless the gas in the tank is stupidly low!
Posted: Thu Mar 06, 2025 1:07 pm
by Jamie Maxwell
I'm having trouble getting an email or message to Scott Conger regarding ordering full flow float valve for an NH straight through model T carburetor - can anyone direct me ???
Posted: Thu Mar 06, 2025 2:18 pm
by Scott_Conger
Jamie
your email came through and I have responded, so check your email
thank you
Posted: Thu Mar 06, 2025 4:44 pm
by Lawrence
Hi, how much each?, and could I have 4 please. And do you take paypal. Cheers
Chris Lawrence NZ
Posted: Mon Mar 10, 2025 11:45 am
by Scott_Conger
Chris
email sent to you
Posted: Wed Mar 26, 2025 10:19 am
by Scott_Conger
Unlike some folks, I will not bump this ad every other day. Every couple of weeks is fine.
Don't wait until the week before your summer tour. Get your car ready while the weather is still cool.
Posted: Sat Apr 26, 2025 11:14 am
by Scott_Conger
This ad is being bumped after 4 weeks of dormancy, hopefully is an example to folks who feel that bumping their own ad every 2 days and driving everyone else's out of sight is really clever. It really isn't. If folks want what you have, they'll find it and buy it, regardless of how often you pimp it.
See you in a few weeks or months
Posted: Sat Apr 26, 2025 12:53 pm
by gtttrobinson
I'd be interested in purchasing two.
Posted: Sun Apr 27, 2025 5:08 pm
by tom leroux
SCOTT
i WILL TAKE THREE
TOM
Posted: Sat Jun 14, 2025 8:13 pm
by Scott_Conger
Six week bump
not one week
not every other day
six weeks
last chance to be ready for the National Tours
Posted: Sun Jun 15, 2025 10:58 am
by Mopar_man
Scott,
I don't know if you did this before but is there a writeup somewhere that shows the difference in float valves and how they work? I've got a 26 so my tank is always above the carb. Some new guys may benefit from your expertise. Including me.
Posted: Sun Jun 15, 2025 11:15 am
by Scott_Conger
Robert
other than Dan Treace doing a write up of my valve in the club magazine a few years ago I know of no one who has ever done a comparison of valves. I can state with certainty, though, that every valve offered commercially (other than mine), has a through-hole that is sized for a modern car using a fuel pump. They are made by major manufacturers whose primary market is for modern cars, and our NH valve was simply an adaptation of every other valve they make (and they all need fuel pumps to operate properly).
My valve is specifically designed for the very low head pressure in a Model T, and the generally higher constant speeds that we run at.
As an example, here is a picture of a disassembled Grose Jet (valve) next to my valve and you'll see that the Grose Jet has a 25% smaller hole than mine which works out to nearly a 50% reduction of flow area. Every other valve has a similarly mis-proportioned body as well.
Grose Jet vs full flow.jpg (32.95 KiB) Viewed 4559 times
Posted: Mon Jun 16, 2025 1:59 pm
by Mopar_man
Thanks so much Scott Now I know!!!! Thanks for all you do for the hobby.
Posted: Sun Aug 10, 2025 10:21 pm
by Scott_Conger
2 month bump
do they work?
viewtopic.php?t=44602
Posted: Mon Aug 11, 2025 7:13 am
by Bmettli
I got my set last week from Mr. C and put it on a fresh rebuilt NH center drain on my 22 touring. Much more pep and power!
Posted: Fri Oct 10, 2025 9:07 pm
by Scott_Conger
Two month bump
not two days
not two weeks
two months
Posted: Sun Oct 12, 2025 2:40 pm
by Wingnut
Scott: I got two of your valves and will need another, I unfortunately bought another T and used one there. This "new" one had a Wizard carb. piece of garbage, I installed a full flo valve in an NH I had and slapped it on. HOLY COW, just like giving Grandpa a dose of Epsom Salts. Many thanks for all your efforts. By the By I forget the price, email me Thanks. Wingnut
Posted: Sun Oct 12, 2025 7:15 pm
by Scott_Conger
Thank you for sharing that :)
I couldn't buy better advertising if I wanted to! :D
email sent
Posted: Tue Oct 14, 2025 11:58 am
by Texasroadkill
Are you interested in selling that wizard?
Posted: Sun Oct 19, 2025 4:41 pm
by Wingnut
Clint, email sent
Posted: Sun Oct 26, 2025 11:16 am
by doug sanford
Scott, I am interested in purchasing 4 full float valves and the tools you sell for removing the seat and jet valve. Please send me a price with the shipping cost included
Thanks, Doug Sanford
402 Frozen Ridge Road
Newburgh, NY 12550
Posted: Sat Nov 01, 2025 9:56 am
by tom leroux
scott
I will take three set please
tom leroux
Posted: Sun Nov 02, 2025 11:11 am
by Scott_Conger
Doug and Tom
please check your personal emails...I've responded to both of you. Thank you.
