single re-babbitted connecting rods
Posted: Thu May 15, 2025 3:45 pm
by Gene_French
i have for sale several single connecting rods ... these are re-babbitted and checked for alignment ... i can machine cut X oil grooves for an extra $15 each ... currently have Standard diameter , -.010" ,and -.020" ... price is $80 each NOT x grooved ...$95 each with machine cut X oil groove and drilled for dipper ... postage is included in lower 48 states ... actual postage outside this area ... it makes GOOD SENSE to have a "spare " connecting rod on hand ... can save the day when on tour ...Gene French 970-581-2808
Re: single re-babbitted connecting rods
Posted: Thu May 15, 2025 3:52 pm
by Gene_French
pictures added including 2 HEAVY typr connecting rods that are re-babbitted and bored -.005" and -.010"...Gene French
Posted: Fri May 16, 2025 8:12 pm
by Gene_French
also have 2 "HEAVY" connecting rods that are re-babbitted and bored to -.005" diameter and -.010" diameter ... the -.005 would be a simple fitting process to use in an original engine with some wear on the rod journals ...Gene French
Posted: Fri May 23, 2025 9:26 am
by Gene_French
to the top ...thanks MTFCA
