WTB - Joe Morris crankshaft
Posted: Thu Jul 10, 2025 12:48 am
by blauvelt
Curious if one is out there.
Re: WTB - Joe Morris crankshaft
Posted: Fri Jul 11, 2025 10:29 pm
by ModelTWoods
I'm curious who Joe Morris is, since no one has answered you.
Posted: Fri Jul 11, 2025 11:26 pm
by Kevin Pharis
Joe Morris made several T crankshafts (couple dozen?) back in the 70’s-80’s. They were fabricated from pins and webs, and meticulously pressed and welded together. Beautiful cranks, but unfortunately most have already broken. I know where some fragments are…
Posted: Sat Jul 12, 2025 1:48 am
by Dan McEachern
Posted: Sat Jul 12, 2025 10:18 am
by Mike Lebsack-Iowa
Dan, I think I have seen an engine with your main bearing caps and one of these cranks.
Posted: Sat Jul 12, 2025 10:39 am
by blauvelt
I figured it was more of hunting for a piece of art and history than anything else. Wasn’t sure if any had survived.
Kevin Pharis wrote: ↑Fri Jul 11, 2025 11:26 pm
Posted: Sat Jul 12, 2025 4:41 pm
by Dan McEachern
Joe Morris was well known in HCCA circles for his knowledge and expertise of one and two cylinder Reo automobiles and rebuilding of the engines. The T cranks he made were because Joe had been fairly successful making Reo crankshafts in pieces and welding them together. Several of the T cranks failed because they were machined with a sharp corner in the fillet of the rear main thrust area rather than a generous radius. I'm not aware of any failures other than the rear flange issue, but perhaps someone else will chime in. AFAIK they were mostly made by Joe, but I understand a few were made by someone who worked with Joe after he stopped. Time wise these were made late '80s / early '90s.
Posted: Sat Jul 12, 2025 5:06 pm
by blauvelt
Thank you for sharing. It really seems that a lot of crank failures on rebuilt and even new cranks come down to not cutting enough radius in the crank journals.
Dan McEachern wrote: ↑Sat Jul 12, 2025 4:41 pm
Posted: Sun Jul 13, 2025 9:52 am
by flatbroke3
deleted my post
Posted: Sun Jul 13, 2025 1:52 pm
by blauvelt
Was it a good one?
flatbroke3 wrote: ↑Sun Jul 13, 2025 9:52 am
deleted my post
Posted: Tue Jul 15, 2025 4:40 pm
by 49willard
I had a Joe Morris crankshaft in my 1907 2 cylinder Buick. It failed after a number of miles when one journal rotated relative to the crankshaft throw.
Posted: Tue Jul 15, 2025 10:22 pm
by Ujustwaite
I have one. I'll upload photos soon.
Posted: Wed Jul 16, 2025 7:22 pm
by Dan McEachern
"It failed after a number of miles ". The $$S solution for Buicks and Reo's was always a new billet crank from Molex or one of the other crankshaft companies, but ..............
Posted: Sun Jul 20, 2025 9:31 pm
by Ujustwaite
viewtopic.php?f=2&t=10178&p=361976&hili ... is#p361958
I forgot that I already posted the photos of mine here. Let me know if you would like more. I have it downstairs in the block but not installed in the car or bolted to an oil pan.
