I am just going to have a pair made. Cast Iron Sunderlin type Rocky Mnt Brake Drum
Posted: Fri Jul 18, 2025 3:14 pm
by NorthSouth
Would anyone have “one” cast iron Rocky Mountain Break Drum. I need to match the one pictured below.
Thanks,
Steve
Los Angeles
Original & Sunderlin (sp) Rocky's had 2 drums cast as one - that's how mine are. -Ed Archer
Re: Need “one” Cast Iron Rocky Mnt Brake Drum
Posted: Fri Jul 18, 2025 4:07 pm
by Sarikatime
Steve, Those are, I believe, two different brake drums stuck together. Call the Rocky Mountain brake drum manufacturers, phone and information available in the Vintage Ford magazin advertisement. Also, maybe call Dave at Chaffins garage, he got me new linings when my brakes got hot and caught on fire.
Posted: Fri Jul 18, 2025 4:51 pm
by RajoRacer
Original & Sunderlin (sp) Rocky's had 2 drums cast as one - that's how mine are !
Posted: Sun Jul 20, 2025 3:54 pm
by NorthSouth
Back to the Top
Re: Need “one” Cast Iron Sunderlin type Rocky Mnt Brake Drum
Posted: Fri Aug 01, 2025 2:10 pm
by NorthSouth
I am still looking for one of these drums.
Posted: Wed Aug 06, 2025 4:08 pm
by NorthSouth
Would anyone have an alternative idea on how to get break drums that will work with and original set of large drum Rocky Mountain Brakes?
Posted: Wed Aug 06, 2025 4:11 pm
by speedytinc
Check with the current mfg. Get dimensions. I believe the drums are the same size, just not the preferred cast iron.
Buy a pair.
Posted: Thu Aug 07, 2025 1:43 am
by Craig Leach
Hi Steve,
The RM drums are advertised as 11 3/4" and the one in your pic looks to be 12" ( the larger drum) I have no idea the width of the cast drums.
Have you giver any thought to having a metal fab shop roll a ring the correct width of 1/8" or 3/16" cold or hot rolled steel that can be heated to
fit over a RM drum so it shrinks to fit tight then welded & machined to the needed specs to match? At least you would not have to worry that it
was worn out?
Craig
Posted: Thu Aug 14, 2025 1:35 pm
by NorthSouth
Maybe the manufacturer’s name is spelled “Sunderland”. I still need one of these break drums to match the one pictured above.
Re: Need “one” Cast Iron Sunderlin Sunderland type Rocky Mnt Brake Drum
Posted: Sun Aug 17, 2025 8:52 pm
by NorthSouth
I need one of these.
Posted: Mon Aug 18, 2025 10:49 am
by Original Smith
Sunderlin is correct.
Posted: Thu Aug 21, 2025 12:27 am
by NorthSouth
I am giving up finding this break drum.
Having two new ones cast.
Re: I am just going to have a pair made. Cast Iron Sunderlin type Rocky Mnt Brake Drum
Posted: Thu Aug 21, 2025 12:30 pm
by Original Smith
Is the company casting your new ones in California?
Posted: Thu Aug 21, 2025 12:38 pm
by speedytinc
Would it be worth while to have extras made? They are superior to the pressed steel.
Posted: Thu Aug 21, 2025 6:44 pm
by kevinf
Steve, check with Cattail Foundry. They are Amish, call leave a number and he will get back to you. He has done a couple of parts for me and does excellent work. He is used to working with original parts as patterns. You can find information on the web even a short news article about the work they do.
Good luck,
Kevin
Posted: Sat Aug 23, 2025 12:11 pm
by JSteele
Steve I would be interested in buying a set.
John
Posted: Sat Aug 23, 2025 12:47 pm
by Mark Gregush
Why not have them cast like the originals, with the inner brake drum as part of the casting or is that your plan?
Posted: Sat Aug 23, 2025 5:31 pm
by Original Smith
The originals were not cast. They were steel. A factory inside drum was riveted to the drum.
Posted: Sat Aug 23, 2025 7:36 pm
by Dan McEachern
To clarify for everyone- the reproduction brakes made by Jack Sutherland (prior to the version currently being manufactured ) were supplied with a one piece cast iron brake drum that incorporated an integral small brake drum in a single casting along with the larger diameter drum. This was Jack's way of duplicating the original two piece riveted assembly that Larry is referring to above.
Posted: Mon Aug 25, 2025 9:53 am
by Mark Gregush
Thanks Dan and Larry. Looking the top photo I got the impression that was how they were made original, a one piece casting.
