spare tire clamp Sold
Posted: Sat Aug 02, 2025 1:17 pm
by Melba Nolan
For sale: spare tire rim clamp $10 plus postage
Re: spare tire clamp
Posted: Tue Aug 12, 2025 4:48 pm
by KWTownsend
I'll take it.
Do you have the bolts for it?
Keith
Posted: Tue Aug 12, 2025 4:55 pm
There are no bolts.
The big hole goes over the existing carrier stud.
The upper hole & notch are for a padlock.
Posted: Tue Aug 12, 2025 5:04 pm
by KWTownsend
Mine has no stud, just a square hole, about 7/16".
Posted: Tue Aug 12, 2025 5:16 pm
There should be a demount able sized fine thread stud swedged from behind.
You'll need to make & secure that stud.
Posted: Tue Aug 12, 2025 5:58 pm
by KWTownsend
My thought was to fabricate one out of a lug bolt.
Posted: Tue Aug 12, 2025 6:14 pm
That can work. Might want to weld/braze into position.
Posted: Wed Aug 13, 2025 12:14 am
by KWTownsend
I just painted it...
Posted: Wed Aug 13, 2025 4:36 pm
by Jack Putnam, in Ohio
Once it is in place. Held by the nut it won't fall out. No need to braze.
Posted: Wed Aug 13, 2025 4:52 pm
Until you remove the spare rim.
Quiescently, I saw a nos replacement carrier base mount last night.
The stud is a fine threaded carriage bolt.
The outer edges of the square of the carriage bolt are chiseled down to lock the square under the bolt head in place.
Posted: Wed Aug 13, 2025 8:10 pm
by KWTownsend
