FS Stewart speedo gears
Posted: Mon Aug 25, 2025 10:52 am
by Karl Von Neumann
Stewart speedometer gear see pics for condition 40$ ea plus the ride
Re: FS Stewart speedo gears
Posted: Mon Aug 25, 2025 9:25 pm
Interesting gear with no spokes Karl. The block printing is early, as is the four hole mounting drilled into the bosses on the casting. Then it has also been drilled for a second four hole mounting. Using the lower right of these holes, two more have been drilled to make a three hole mounting like the later gears.
Allan from down under
