Seeking 1915 Rear Radius Rod
Posted: Tue Sep 02, 2025 1:17 pm
by mortier
Anyone have a spare 1915 rear radius rod? The threads on one of the rods on my car are stripped.
Phil Jamison
Re: Seeking 1915 Rear Radius Rod
Posted: Tue Sep 02, 2025 4:32 pm
by Karl Von Neumann
Is it a cast iron end on the diff side you should probably just repair it it will be cheaper
Posted: Tue Sep 02, 2025 6:50 pm
by Allan
Phil, yours is repairable if you want to go down that track. The worn section can be built up with weld, then ground/filed back into round. The good thread on the end gives you a lead-in to then use a die to make a new thread.
I have found 2 or 3 variations in the length of the round section of those rods, so finding a matching one, if that is important to you, may be a little frustrating.
Allan from down under
