FS KW Brass Master Vibrator Switch
Posted: Wed Sep 10, 2025 12:56 pm
by ThreePedalTapDancer
Nice brass KW Master Vibrator switch with key. Nice crisp lettering. Ready to mount and use. 50 includes shipping.
Re: FS KW Brass Master Vibrator Switch
Posted: Fri Sep 19, 2025 3:55 pm
Nice switch
Posted: Sat Sep 20, 2025 4:01 am
by Wayne Sheldon
Not a master vibrator switch. It is a security key switch that covers over the late 1913 into about 1920 non-starter cars and trucks with the ignition switch mounted directly on the coil box. Those factory switches from the Ford factory used a single universal key. Anyone with a key could walk down the street and steal any car whether the owner left his universal key in the car or not.
Similar to yours keyed switch covers were manufactured by several companies. Some would work with the Ford factory switch. Some used special switches which were more tamper proof than others. I had one that was missing the key, and it was a bear to get apart without destroying the switch which I was hoping to use.
A really nice accessory!
Posted: Sat Sep 20, 2025 11:30 am
by RajoRacer
I beg to differ there, Wayne - it's exactly what it is as stamped on the face ! I have a KW Master coil. Here's a KW coilbox lock.
Posted: Sat Sep 20, 2025 1:23 pm
by TRDxB2
The KW AUTOLOCK fits over the KW switch that accepted many different style covers. The KW Master Vibrator switch plate could fit over those but needs the switch lever (arrow) to replace the standard in the KW switch. The top of the body shapes match. Neat switch plate
Posted: Sat Sep 20, 2025 9:58 pm
by RajoRacer
And, your point is, Frank ?
Posted: Mon Sep 22, 2025 7:04 am
by rickd
Pic of my KW coil box ignition switch. The internals are the same as Eds' master vibrator but the switch internal connection lever is designed to turn by the Yale/KW key versus the normal round ignition key. Nice switch Ed, the patent date on my switch is the same as yours. Also of note the internal tumbler of these switches have a serial number engraved on it that matches the serial number on the Yale/KW key.
