Fronty Overhead rocker arms
bobster1
Topic author - Posts: 123
- First Name: Bob
- Last Name: Richmon
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1919 Paco Speedster, 1907 Model N, 1907 Model S Runabout, 1909 Indian, 1910 Maxwell AA, 1910 Buick Model 16 Roadster
This was my best Hershey Find last week, does anyone recognize who may have made these? My question is about the pushrods, specifically the ends that fit the “Ball Adjusters” that screw into the rocker arms. I didn’t get that part, but I’m assuming that it’s a readily available part? Any leads are appreciated, thanks, Bob
Bob Richmon, 804 339 0584 bobveco@aol.com, 04 CDO, 07' Model N, 07 Model S Runabout, 10 Buick 16 Roadster, 11 T Tour, 19 Paco Speedster, 09 Indian, 10 Maxwell
Mark Chaffin
- Last Name: Chaffin
Re: Fronty Overhead rocker arms
Looks to be 5/16 ball. Check out MANTON Pushrods. They have an extensive online catalog. They will make whatever you need.
https://mantonpushrods.com/
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
You may find that the rocker stands are not Frontenac, as all models of Frontenac heads used a single bolt to hold the rocker stands to the head.
B and BB Rajo heads utilized a two bolt rocker stand that may well fit the rocker stands you show above. Just something to be aware of. Redrilling the top of a Fronty head to use the two bolt rockers above might not work out too well, as the tops of Fronty heads are quite thin except around the original rocker stand bolt holes. Just a heads up. Looks like a nice set of rockers!!
bobster1
- First Name: Bob
Thanks everyone for the response, the original maker has contacted me! Regards, Bob
