WTB: Stipe High Lift Camshaft
frontyboy
Topic author - Posts: 497
- First Name: dick
- Last Name: dock
- * REQUIRED* Type and Year of Model Ts owned: T sprint cars
Would like to buy a hi lift Stipe cam new or used.
thnx
frontyboy
thnx
frontyboy
Bill Anziani
- First Name: Bill
- Last Name: Anziani
- * REQUIRED* Type and Year of Model Ts owned: 1924 Coupe
Re: WTB: Stipe High Lift Camshaft
I believe Kevin Pruis sells them or something very similar
Mike Penserini
- First Name: Mike
- Last Name: Penserini
- * REQUIRED* Type and Year of Model Ts owned: 27 roadster pickup, brass speedster, Mercury # 253 B, Mercury # 1070, Faultless "Hoosier" parts collection.
Yes, Kevin Pruis is selling a Model T performance cam.
blauvelt
- First Name: Douglas
- Last Name: Ogden
3 degrees exhaust overlap?
ewdysar
- First Name: Eric
- Last Name: D
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Speedster #32, 1916 Touring, 1927 Runabout
Nope. Here is the same info in a more readable table format, from the "Model T Cam Project" on the Model T Ford Club of Tulsa webpage.
https://mtfctulsa.com/Cams/design_280.html
Keep crankin',
Eric
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
There is s slight typo in Kevin's timing tag that makes the timing events a little hard to read and might be somewhat confusing:
The red circled line should probably not be there for the intake timing event:
a minor point, but..............
Adam
- First Name: Adam
- Last Name: Doleshal
Needs to remove the line after 54 and change ABCD to ABDC…
And 10 needs to be changed from ATDC TO BTDC…
ewdysar
- First Name: Eric
- Last Name: D
While the 10 related to the intake opening looks to be BTDC in the data graphic, you can see in the specs that the intake opening is indeed 10 ATDC, the image is wrong for this cam. But I believe that the blank format graphic for these figures is more commonly used for cams in modern, higher speed engines that do have exhaust overlap with the intake opening BTDC and the exhaust closing ATDC. The figures added to the graphic for this cam do match the .280 lift cam data provided above, even though the graphic doesn't quite fit.
Keep crankin',
Eric
frontyboy
- First Name: dick
- Last Name: dock
How much? still available?
frontyboy
frontyboy
Dan McEachern
- First Name: DAN
Allen is correct on the ABDC. Eric is correct on the ATDC valve event. Kevin does have cams available. Best to contact him at the above #.
Etudes10
- First Name: Greg
- Last Name: Cosner
- * REQUIRED* Type and Year of Model Ts owned: 1915 touring, 23 coupe, 26 speedster, 25 tudor, 25 TT
https://ebay.us/m/17Myws
Listed on ebay.
Listed on ebay.
