Kingston 4 ball carburetor
Posted: Fri Oct 31, 2025 11:44 am
by Corey Walker
New float, viton tipped needle and seat conversion, new choke spring, reconditioned spray needle, throttle shaft bushing installed.
The original throttle arm/shaft and petcock were missing so I used a modified Holley G throttle shaft and Kingston L2 drain valve.
$400 postpaid to continental USA email: wlkma9@gmail.com
Re: Kingston 4 ball carburetor
Posted: Fri Oct 31, 2025 11:48 am
by Corey Walker
Pictured is the Holley throttle arm on the left and an original Kingston on the right. Not a noticeable difference and the staple instead of 2 screws to secure the plate aren’t visible once installed.
Posted: Thu Nov 06, 2025 10:21 am
by Corey Walker
Back to top.
