1912 Front Hub How Do I Remove The Rac?
Posted: Tue Nov 11, 2025 3:20 pm
by Bill Everett
How do I remove the race seen in the picture? Ny help woold be great!
Re: 1912 Front Hub How Do I Remove The Rac?
Posted: Tue Nov 11, 2025 3:35 pm
Grind a bar/plate to fit in the race about 1/2 way down. Weld onto the race with a wire welder.
Tap it out against the welded plate/bar with a rod/pipe from the opposite side.
Posted: Tue Nov 11, 2025 4:22 pm
by Don ellis
put a couple of welds on it with the wire welder and it will fall out
Posted: Tue Nov 11, 2025 8:20 pm
by Mike Silbert
I second welding in a bar, works great, used it multiple times to remove something stuck like that.
It never fights after that unless it is defective already.
Posted: Wed Nov 12, 2025 7:51 am
by Loftfield
No welder? Use rotary carbide rasp to cut into the race, tap with hammer to loosen race. If no success use a bigger hammer.
