Zenith carburetor looks good still has the float inside, not sure what it fits. $200 plus shipping est. $23.00
Best way to reach me is Text or call 423_284-97fifty. Check or postal money order only.
FS—-> Brass Zenith Carburetor
Runabout
Topic author - Posts: 318
- Last Name: McClelland
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1911 Mother-n-law roadster, 1919 Coupe, 1920 Depothack, 1922 Centerdoor, 1923 Roadster, 1923 Speedster, 1924 TT Truck,
ModelTWoods
- First Name: Terry
- Last Name: Woods
Re: FS—-> Brass Zenith Carburetor
Most updraft Zeniths had a model number stamped on a 'pad' on the carburetor body. The entire body with the pad location isn't visible in your pictures. Do you see any other numbers on the carburetor?
Runabout
No other numbers except what’s stamped on the flange. Z5. V, and what looks to be a T
Down on the intake throat There’s an A with the center closed.. could be an arrow..? I’ll add more pictures soon.
Runabout
Pictures added….
Bits & pieces of info from the internet. The model is 36 FZ (not sure about the A) The 36 refers to the bore size. A more popular look alike is a 22 FZ for an Austin 7. Someone mentioned it might be for a truck do to the larger boar size
Picture of a 22 FZ
Picture of a 22 FZ
Runabout
Thanks for your input Frank….I’m sure someone out there needs it, just a matter of the right person seeing it.
