Found a 26-27 headlight. Thanks
Posted: Sun Dec 07, 2025 9:13 pm
by Reno Speedster
I am looking for a decent 1926-1927 headlight. Let me know what you have and need for it.
Re: WTB 1926 -27 Headlight
Posted: Sun Dec 07, 2025 10:55 pm
by Mike Silbert
Which style do you want?
"1926" style that mounts to the fender
or
"1927" style that mounts to the headlight bar
Pictures from the MTFCA Encyclopedia web pages
Posted: Sun Dec 07, 2025 11:30 pm
The earlier type also comes in Left and right side applications.
Posted: Mon Dec 08, 2025 12:40 am
by Reno Speedster
Thanks Allan, I am looking for the later one mounted on the fender tie rod.
Posted: Mon Dec 08, 2025 9:15 am
by MotoBrew
Langs has them. I had to replace one on my 27.
https://www.modeltford.com/item/6512.aspx
They also have a rebuilding kis in chrome and nickel. I used one of the nickel ones. It is a good kit but required me to slightly reduce the outer diameter of the reflector to get it to fit properly onto the head light bucket. I compared the original reflector to the replacement and the replacement was definitely slightly larger in outer dia. This caused it to not fit/seat correctly into the bucket. Once I sanded down the OD of the replacement it fit just fine.
