For Sale: 1926-1927 Roadster Top Irons
Posted: Wed Dec 17, 2025 6:50 pm
This is a set of top irons for 1926-1927 roadsters. These will need some work or could be used for parts.
This set is rusted, pitted, bent, and cracked. One of the main irons is missing the end piece that connects to the body and the end for the other main iron has been sloppily welded back on. All of the wood will need to be replaced. The hinge pins will need to be freed up where the two irons are connected.
If you have ever looked for these you know how difficult it can be to find a set and how much a good set normally goes for. These are not being reproduced.
$250 plus shipping in the U.S.
