FS REAR AXLE BEARINGS (SOLD)
Posted: Fri Dec 19, 2025 4:42 pm
by Mark Chaffin
Set of four used rear axle bearings with tight cages. They come greasy and will require cleaning prior to use. Price is $60 plus $8.50 shipping per set. I have eight sets available. Mark Chaffin (951) 805-0928
Re: FS REAR AXLE BEARINGS
Posted: Fri Dec 19, 2025 5:29 pm
by Mark Chaffin
One set going to Matt.
Posted: Fri Dec 19, 2025 11:05 pm
by laltenhofen
Would like a set.
Posted: Sat Dec 20, 2025 6:17 am
by MotoBrew
Would like a set please. text and pm message sent
Posted: Sat Dec 20, 2025 10:26 am
by Mark Chaffin
One set going to Steve.
Posted: Sat Dec 20, 2025 10:32 am
by Mark Chaffin
One set going to LaVon.
Posted: Sat Dec 20, 2025 10:41 am
by Mark Chaffin
One set to Barry. One set to Kurt.
Posted: Sat Dec 20, 2025 12:15 pm
I would want to know the size of the rollers before buying.
Posted: Sat Dec 20, 2025 12:45 pm
by Mark Chaffin
Even IF the rollers had .010 wear, still far superior to the solid roller bearings. Of course these do not have that kind of wear and the price is very reasonable.
Posted: Sat Dec 20, 2025 1:30 pm
by Russ T Fender
I’ll take a set if one is left
Posted: Sat Dec 20, 2025 1:49 pm
by Karl Von Neumann
Mark Chaffin wrote: ↑
Mark maybe you should make a official announcement that they are usable with up to .010 wear I know that but alot of guys if they are over .004 guys won't touch them I have boxes of them guys just won't buy because of that
Posted: Sat Dec 20, 2025 1:54 pm
I've rebuilt many rear axle assemblies & have found the best sleeves available are a smidge larger than stock Ford therefore using a near perfect bearing at .498 - .499, install too tight for my liking - I go through mine to locate a .495 - .496 to run in the repro sleeves. I've never in 40+ years located a .500 roller !
Posted: Sat Dec 20, 2025 2:39 pm
by Art M
I talked to a bearing senior project engineer who had a lot of experience with these type of roller bearings, called wound roller bearings. About 8 years ago, he recommended at least .005 inch of radial clearance at the minimum. The Chief Engineer at the time of the last production (1989) of wound roller bearings agreed. The project engineer passed about 5 years ago. The chief engineer winters in Florida and returns to Ohio in the summer.
Solid roller bearings have given good service at 8,000 miles and still going. which were installed properly. However, there seems to be an adequate number of useable wound roller bearings at this time.
Art Mirtes
Posted: Sat Dec 20, 2025 8:13 pm
by Mark Chaffin
Like Steve stated. New sleeves. New axles. No problem. Cleaned and properly installed. They will outlive us all. To each his own.
Posted: Sat Dec 20, 2025 8:17 pm
by Mark Chaffin
One set to Val.
Posted: Mon Dec 29, 2025 5:31 pm
by Mark Chaffin
One set to Joshua.
Re: FS REAR AXLE BEARINGS (SOLD)
Posted: Mon Dec 29, 2025 6:25 pm
by Mark Chaffin
Last set going to Dean. Thanks all.
Posted: Mon Dec 29, 2025 7:08 pm
Karl Von Neumann wrote: ↑
Mark maybe you should make a official announcement that they are usable with up to .010 wear...
They're not. (They're just better than the solid rollers...)
Even more important than size, is taper. I won't use rollers tapered more than .001/.002.
