Wanted: gas tank filler
Brent
First Name: Brent
Last Name: Coil
* REQUIRED* Type and Year of Model Ts owned: 1914 1917 1926 1927
Post by Brent » Sun Feb 22, 2026 11:57 am
I need the filler opening that the gas cap screws into for a 26-27 Tudor gas tank. If you have an old rusted tank that still has good threads for the filler neck please message me. Thanks
Karl Von Neumann
First Name: Karl
Last Name: VonNeumann
Board Member Since: 2022
Re: Wanted: gas tank filler
Post by Karl Von Neumann » Tue Feb 24, 2026 12:00 am
I think I have a junk cowl tank in storage ill have a look when im out there tmrw
Karl Von Neumann
First Name: Karl
Post by Karl Von Neumann » Tue Feb 24, 2026 1:59 pm
I did look ive got a bad tank but the neck is pretty crusty
Wingnut
First Name: William
Last Name: Reep
* REQUIRED* Type and Year of Model Ts owned: 1924 roadster, 1926touring, 1926 Coupe
Post by Wingnut » Tue Feb 24, 2026 6:53 pm
I have a tank I'm not going to use, someone had tried to seal it with red coat inside and a God awful slather of some rubbery sealer outside. the threaded filler neck is just fine. contact me @ three three 0Twofour12sixfour1 you can call or text. Wingnut
