Free to good welder, spoken for
RGould1910
Last Name: Gould
Post by RGould1910 » Sat Mar 07, 2026 1:53 pm
Transmission driven gear puller. Broke on pulling off a very stubborn repro driven gear. Worked like a champ before. Cost is zero. You pay Priority postage. Email me via the website.
Richard Gould
Re: Free to good welder
Post by Scott_Conger » Sat Mar 07, 2026 2:45 pm
For anyone in the future:
This puller is a cam gear puller 5Z320 and was for pulling the small timing gear off the end of crankshafts
The 5Z326 Transmission Gear Puller looks just like this but doesn't have the raised lip at the tip
Post by speedytinc » Sat Mar 07, 2026 3:45 pm
I have several that have that same undercut on the arms. They all fit the driven gear. Mine are all numbered 3Z611.
If you squeeze the arms together a bit & remove the big chunk of steel off the screw it will work as a very good puller for rear wire wheel hubs.
Rodger Erickson
First Name: Rodger
Last Name: Erickson
Post by Rodger Erickson » Sat Mar 07, 2026 5:55 pm
Regarding rear wire wheel hub pullers, I've had success with a Harbor Freight Tie Rod and Pitman Arm Puller ($13.99.) You will need to grind off the insides of the tips by just a small amount to slide into the groove. Nobody should ever have to feel guilty about grinding, hacking, tweaking, or wrecking Harbor Freight tools.
RGould1910
Last Name: Gould
Re: Free to good welder, spoken for
Post by RGould1910 » Sat Mar 07, 2026 10:37 pm
Thanks for the clarification Scott. New info for me.
