It’s straight and only in need of some minor work. There are no brackets with it. I may have a pair of nice original cast rear frame to body brackets available at additional cost if you need them, but I don’t have any other brackets.
Has a couple extra holes that need filling. Has some scattered areas of pitting, but otherwise smooth. Right front crossmember has bolts in it, but Left has factory rivets. Rear crossmember has some cracks at the corners of the spring tie bolt hole. All easy fixes for someone with basic experience.
$995 Will take it. Please email. I may not see or respond to a p.m. First email in my inbox has first option to purchase it.
Thank you.
