Zero Maintenance Timer
MKossor
Last Name: Kossor
MTFCI Number: 22706
Post by MKossor » Sun Jul 28, 2019 11:19 pm
The I-Timer is a direct replacement for the stock Model T mechanical timer. It provides reliable and consistent coil activation, precisely synchronized with piston position and never needs maintenance. Start on battery and run on Magneto or battery as usual. The I-Timer is immune to timing cover misalignment and provides precise ignition coil activation without wiper bounce, contact skip, contact wear, arcing or other mechanical flaws. Imagine never having to clean, lubricate or replace your timer ever again! Simply replace your mechanical timer with the I-Timer and enjoy smooth, optimal engine performance at any engine speed with properly adjusted stock Model T coils.
Zero Maintenance I-Timer: $399.95 Order at: www.modeltitimer.com
