Fronty oil water pump magneto sidedrive F/S
Topic author - Posts: 899
- First Name: Layden
- Last Name: Butler
Frontenac side drive setup for Model T Ford, water pump and magneto mount beside the engine with oil pump being driven in front from the end of the Model T camshaft, what you see is what I have, yes it needs machining to finish.
