Duplex spare tire carrier
Gene_French
First Name: Gene
Last Name: French
Board Member Since: 2014
Post by Gene_French » Fri Aug 16, 2019 11:34 pm
for sale … Duplex double spare tire carrier … good condition … will need key made and mounting bracket … price is $100.00 plus postage … will need to know your zip code for postage rate … always an optimist Gene French ph. 970-581-2808 ...address 49519 cr.23 Nunn, Co. 80648
Chris Haynes
First Name: Chris
Last Name: Haynes
Re: Duplex spare tire carrier
Post by Chris Haynes » Sat Aug 17, 2019 6:38 pm
How does it attach to the car?
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Sun Aug 18, 2019 12:02 am
It does not attach to the car. It clamps the second spare to your existing spare which is held to the car by your existing carrier.
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sun Aug 18, 2019 11:22 am
Layden:
thanks for the info. … I have never used a unit like this … my Dodge Brothers touring has a 3 point mount for the spare … can see how this would work though by clamping to the first rim in the oem mount … always an optimist...gene french
Post by Scott_Conger » Sun Aug 18, 2019 6:13 pm
And to my chagrine I have found these to be mostly for 21" split rim wheels and not for 30 x 3 1/2 demountables. You might wish to check and see.
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sun Aug 18, 2019 9:03 pm
Scott:
I don't have any 21" split rims … I did compare it to a 21" wire wheel and it would be within the range of the adjustment to clamp onto a 21" rim … have had this unit for probably 25 years … got it with a large group of parts in a bulk purchase … I am clearing out some of this bulk … I have WAY too much STUFF ! always an optimist ...Gene French
