Looking for a bare front axle
70shovelhead
First Name: Preston
Last Name: Wells
Board Member Since: 2008
Post by 70shovelhead » Thu Aug 15, 2019 6:30 pm
Looking for a front axle for a 26 TT. Dont need spindles or king pins.
70shovelhead
"There is more to life than what we see"
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
1919 IHC Titan 10-20
Re: Looking for a bare front axle
Post by Scott_Conger » Thu Aug 15, 2019 6:34 pm
I cannot help with supplying the part, but if you have all the other stuff, perhaps yours is damaged?
Most can be worked back to shape quite readily with a heavy press, and in fact most need it, though most don't get it.
Full Flow Float Valves - deliver fuel like Henry intended!
Post by Mark Gregush » Thu Aug 15, 2019 7:46 pm
Just in case, any bare front axle will work from about 1915 to 1927, unless you are looking for one with a date forged into it. TT's and cars used the same front axle.
1921 Huckster
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Fri Aug 16, 2019 1:59 pm
I should have a good one, $100.00 plus shipping. Contact me if interested.
Hank
Scott Gilham
Last Name: Gilham
Post by Scott Gilham » Sun Aug 18, 2019 9:01 pm
sent you a PM
