Duplex spare tire carrier
Posted: Fri Aug 16, 2019 11:34 pm
by Gene_French
for sale … Duplex double spare tire carrier … good condition … will need key made and mounting bracket … price is $100.00 plus postage … will need to know your zip code for postage rate … always an optimist Gene French ph. 970-581-2808 ...address 49519 cr.23 Nunn, Co. 80648
Re: Duplex spare tire carrier
Posted: Sat Aug 17, 2019 6:38 pm
by Chris Haynes
How does it attach to the car?
Posted: Sun Aug 18, 2019 12:02 am
by Layden Butler
It does not attach to the car. It clamps the second spare to your existing spare which is held to the car by your existing carrier.
Posted: Sun Aug 18, 2019 11:22 am
by Gene_French
Layden:
thanks for the info. … I have never used a unit like this … my Dodge Brothers touring has a 3 point mount for the spare … can see how this would work though by clamping to the first rim in the oem mount … always an optimist...gene french
Posted: Sun Aug 18, 2019 6:13 pm
by Scott_Conger
And to my chagrine I have found these to be mostly for 21" split rim wheels and not for 30 x 3 1/2 demountables. You might wish to check and see.
Posted: Sun Aug 18, 2019 9:03 pm
by Gene_French
Scott:
I don't have any 21" split rims … I did compare it to a 21" wire wheel and it would be within the range of the adjustment to clamp onto a 21" rim … have had this unit for probably 25 years … got it with a large group of parts in a bulk purchase … I am clearing out some of this bulk … I have WAY too much STUFF ! always an optimist ...Gene French
