For Sale - Speedster Parts
TonyB
First Name: Tony
Last Name: Bowker
MTFCA Number: 32
Post by TonyB » Thu Aug 22, 2019 1:04 pm
I have model B exhaust manifold with a model A intake and rebuilt carburetor setup. Had it running on my T but decided to put it back to stock. The setup comes with a new muffler and exhaust pipe professionally bent to make sure it does not hit the frame since it is larger than a stock T. The carburator has an adapter to take the carburator in closer to the motor, otherwise the carb sticks outside of the hood. Since the carburator is lower than stock there is no need for a fuel pump. There is no cutting or welding, everything bolts right up.
Pictures available on request since I can’t download them onto the website. I have way over a thousand dollars into the setup. Will take $ 700. Or best offer. Plus freight.
This setup will give more power and speed, especially on lower elevations, not like where I am at 5500 feet where it worked very well but decided to go back to stock T due to looks on my 12 towncar. Frank Seress. 818-254-6797
Tony Bowker
Ramona, California
1909 Touring, 1914 Touring, 1915 Speedster, 1924 Coupe.
Sarikatime
Last Name: Seress
MTFCA Number: 27707
Re: For Sale - Speedster Parts
Post by Sarikatime » Fri Aug 23, 2019 10:58 am
Thank you Tony. Frank
Post by TRDxB2 » Tue Aug 27, 2019 12:57 pm
Adding Pictures for Frank Seress - still available
Sarikatime
Last Name: Seress
MTFCA Number: 27707
Post by Sarikatime » Wed Aug 28, 2019 9:07 am
Everything is either new or rebuilt and has less then ten miles of operation while it was on my car. The exhaust pipe is even wrapped to reduce heat coming into the cab. Frank
BobD
First Name: Bob
Last Name: Doris
MTFCA Number: 32538
Post by BobD » Fri Aug 30, 2019 2:45 pm
To Top.
Sarikatime
Last Name: Seress
MTFCA Number: 27707
Post by Sarikatime » Wed Sep 04, 2019 4:11 pm
There must be someone out there that needs these parts.
Time4T
First Name: Patrick
Last Name: Feeney
Post by Time4T » Tue Sep 17, 2019 8:17 am
Hi, is the setup still available?
Sarikatime
Last Name: Seress
MTFCA Number: 27707
Post by Sarikatime » Tue Sep 17, 2019 8:22 pm
Patric, the setup is available. Frank
Sarikatime
Last Name: Seress
MTFCA Number: 27707
Post by Sarikatime » Wed Sep 18, 2019 8:19 pm
Patrick, look in your spam folder since this is the first time you have a mtfca conversation. Tony Bowker posted the pictures for me, that is why his name is on the post, you can varify it with him, but the setup is mine. Frank
