This timing gear cover is for the Bosch magneto that has the 3 gears in a case and driven off the cam. That is why there is no provision for a timer. Stamped 61788. Nice shape.
$125 plus shipping
Scott 971-5O6-94O2
Accessory Bosch timing gear cover
- First Name: Kevin
- Last Name: Pharis
Re: Accessory Bosch timing gear cover
Glad to see an original! This one is exactly alike the couple others I have come across, except that the part number is stamped into the front... the others have raised lettering (RM XXXXXX) on the inside, similar to how the Bosch distributor plates were done
Here’s a pic of one in action! Note that these mag drives can be used on later generator style motors when used in conjunction with the generator block off plate used in ‘19-‘20
Topic author - Posts: 297
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1923 Mercury speedster replica, 1923 speedster
Thanks Kevin for showing those pictures.
Sold to Brent
