Rajo Fronty Aluminum Flat Drive Oil Pump Lincoln Mdl L
henryford2
First Name: Joseph
Last Name: Andulics
MTFCA Number: 9766
Post by henryford2 » Thu Nov 07, 2019 12:24 pm
This pump was identified for me by the late Phil Mino as being for the Lincoln Model L V-8, 1924-26 and or 1927-30. It was commonly used on the Model T racing engine mounted to a custom aluminum front plate or a modified stock timing gear cover. I've attached a picture from Speedway Motor Museum of American Speed mounted to a Rajo engine. It would be "period" correct for the Model T ear race car or speedster. Appears to be in good shape, no obvious wear patterns in the aluminum or gears. The driven shaft appears to slip over the end of the Model T camshaft and held in place with a pin through the timer roller hole. Difficult to put a price on since it is "period correct" for the Model T and its value if you own a Lincoln of this model. I'm throwing it out there at $175 including shipping in the CONUS. I would be happy to be "educated" on its real value and open to offers. Thanks, please reply to the attached email.
henryford2
First Name: Joseph
Last Name: Andulics
MTFCA Number: 9766
Re: Rajo Fronty Aluminum Flat Drive Oil Pump Lincoln Mdl L
Post by henryford2 » Thu Nov 07, 2019 12:26 pm
more
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Thu Nov 07, 2019 3:37 pm
I will take it.
henryford2
First Name: Joseph
Last Name: Andulics
MTFCA Number: 9766
Post by henryford2 » Thu Nov 07, 2019 4:21 pm
SOLD , sorry Layden sold to an earlier email response.
